Wiring Teco FM50-202-C
- CNC Control System Serial Number: e415f6f57684-0210214350
Re: Wiring Teco FM50-202-C
I just got this working on my mill. I wired V0 and V1 to the analog outputs and sent 24v to the spin forward from a dry contact. Then I set the parameters on the drive F10 and F11 to 1 so the VFD would look to the terminals for control. It runs fine and the speed control works, but at low speed it has little torque. I thought the VFD should be able to pump up the power to maintain speed. Have you guys had any low speed torque problems with the FM50 ?
