Acorn Geckodrive g320x
Re: Acorn Geckodrive g320x
ok, now we are at a good baseline.
the disk images show that this is classic Lost Motion.
with the machine off
put your hand on the screw
turn the screw 1/8th - 1/4 of a turn CW then CCW, back and forth.
you will feel the 'lost motion' you will be able to rotate the screw for a number of degrees that will result in NO motion on the table.
perform this test.
perform this test.
1 user liked this post
- CNC Control System Serial Number: qc470
Hello friend I already performed this test and there is no loss of movement on the table, please watch the video I uploaded below.
I've already done the backslash adjustment once and it was a very small 0.02mm fit. When I do the one-way motion test, for example on X or Y, it moves perfectly when it goes in direction + or - the needle of the dial comparator is in the same position. But when I make a circle it comes out deformed.
loose motor or screw pulley?
loose Motor encoder?
drive not working with encoder feedback?
post the g code program you are using for the images!
The screw is not loose the pulley of the motor is well secured I did the test you told me, and the movement is perfect please The screw is not loose, the pulley of the motor is well secured, I did the test you told me, and the movement is perfect, please see the video I uploaded to YouTube
I don't understand what you want to tell me??
Friend please watch this video, my machine is perfect in its movement in all its axes but the circles continue to come out deformed, please watch the video that I uploaded to YouTube carefully, here I place the link watch this video.
https://youtube.com/shorts/60BtwWWOlFQ? ... gEt1GS4hLv
