Build Thread - Emco 320
Re: Build Thread - Emco 320
No Encoder output Z /Z
more reading here:
https://centroidcncforum.com/viewtopic. ... 0&start=10
more reading here:
Ah ok, I had seen that when I searched. Just checked. I have access to that via the pins, just need to solder more wires. Appreciated.
Got the parts, didnt see the SSR in your drawing but wired it up. Couldnt get it to work initially and of course the pulse isnt there for long. It looks like their In / Out for the Z itself is swapped. My writing on the part doesnt match yours exactly (suppose depends on if you are looking from top or bottom). Changed the input, it triggers and after some messing about, managed to get a normal relay to trigger and after more messing about, it looks like its homing now and then finding index and setting X. Thanks for your help. Ill see if I can get an SSR. Interesting that Centroid doesnt switch the input LED quick enough but at least the software sees the state change and triggers the event.suntravel wrote: ↑Fri Jan 24, 2025 9:44 am No Encoder output Z /Z
more reading here:
Chaz wrote: ↑Wed Jan 29, 2025 10:11 amInteresting that Centroid doesnt switch the input LED quick enough but at least the software sees the state change and triggers the event.suntravel wrote: ↑Fri Jan 24, 2025 9:44 am No Encoder output Z /Z
more reading here:
are you using advanced PLC i/o screen? its quicker than the Simplified i/o menu
Ah, I think simplified, let me change that however I'm referring to the LED on the board, not the PLC view. Let me check it again tomorrow. I might make a vid of it to see which is seen / not. The SSR Ive ordered should be delivered tomorrow however have a fairly busy day before I can fit it.cnckeith wrote: ↑Wed Jan 29, 2025 5:17 pmChaz wrote: ↑Wed Jan 29, 2025 10:11 amInteresting that Centroid doesnt switch the input LED quick enough but at least the software sees the state change and triggers the event.suntravel wrote: ↑Fri Jan 24, 2025 9:44 am No Encoder output Z /Z
more reading here:
A fly will see the LED lit up, I am to slow also
So, LED status doesnt change and the Advanced IO doesnt change either yet it detects the pulse. The SSRs that I bought dont work, it has around 1200 ohm impedance over the output when it switches (versus around 1450 before). Odd. Maybe there just isnt enough current to fully switch it. The relay works however so will use that.
Coming back to this. If I have T0101 and I type T0202 in the MDI, the tool offset changes but the M6 macro does not run. The only way to 'force' M6 to run is to do M6 T0202 in the MDI. What do I need to set (potentially in parameter 160?) for me not to need to use M6 in the MDI command please? This also means that I wont have to edit any of the conversational code that is generated once it posts.
It is a lathe.
It is not supposed to run an M6 macro when the tool number changes.
It is supposed to run the "cnctch.mac" macro when the tool number changes.
That would make sense, thanks. I presume I just transfer my custom code in M6func to cnctch? Will try it later once it warms a bit.
