AC Servo suggestions?
Re: AC Servo suggestions?
oo those are pricy haha. My delta sets were about half the price.
Yes they are cheaper on Ali, but not with next day delivery on purchase or in case of guarantee...
I buy them in Taiwan directly. But you are correct. Other than a bit of support by the manufacturer ... you are mostly on your own.
- CNC Control System Serial Number: 0035FF8A1900-10082038
Thanks for the info, I’ll probably order a 1kw JMC setup for testing at some point, it will good to have a cheap option available.
As an FYI for others interested, I picked up my ASDA-B3A ethercat drives (which can do both ethercat and step/dir) from FastToBuy. Great customer service and responsiveness communication with them via WhatsApp. Cost for 750 watt servo motor and drive was about $450. The ethercat version of the ASDA-B3 drive doesn’t support step/dir, so be cautious if you are hoping to use both methods or don’t know what centroid control you are going to use.
I purchased a 2.6KW JMC servo for a spindle motor for myself on ebay, then ordered another one for a friend directly from JMC. The 2.6KW servo with driver delivered to Texas was about $500.00.
My contact at JMC is:
Holly
sales1@jmc-motion.com
They were very accommodating and helpful with a few technical questions. I have attached the latest manual.
Best... Richard
Holly
Best... Richard
- JAND Use Manual_20240316090818.pdf
- (3.02 MiB) Downloaded 6 times
You are sure that you have a JAND driver, not a JASD ?
Good question,
The 2.6KW model I ordered was discontinued and replaced with another very similar model. Please see email below from JMC that details exactly what was ordered for my friend. It looks like the driver is a JASD. I have attached this manual.
Sent: Wednesday, March 13, 2024 11:45 PM
To: Richard Salzman <richardsalzman@hotmail.com>
Subject: Re:FW: RE: Technical Specifications: 130JASM526225K-17BCT
Hello Richard,
130JASM526225K-17BCW + JASD30002-20B:$357/set
The difference between the two models is a little different in size, the same 2.6KW
Please check the attached motor drawings and torque diagrams.
If you have any questions just let me know.
Thanks & Best regards,
Holly
Shenzhen Just Motion Control Electromechanics Co.,Ltd.
TEL: +86-0755-26509689
Wechat/WhatsApp:+86 18123718365
SKYPE: Holly Deng
QQ: 2355528511 | www.jmc-motor.com
Hello Richard,
Holly
SKYPE: Holly Deng
- JASD series AC servo manual.pdf
- (5.91 MiB) Downloaded 2 times
