Houseman303
Posts: 118 Joined: Sun Nov 12, 2023 1:33 pm
CNC Control System Serial Number: A901313
Post
by Houseman303 » Sun May 19, 2024 2:55 am
Fordmasterkw wrote: ↑ Fri May 17, 2024 12:49 pm
I'm dealing with same issue/different servo though. I have been trying to correct it but have been unsuccessful so far. Just started all of the sudden.
So I will be following this closely.
What power do the servo drives have? What does the surface look like when you machine a square component? If the surface then looks better, the servo drives are not set correctly or their holding torque is too weak
Houseman303
Post
by Houseman303 » Sun May 19, 2024 3:03 am
rigid holding is the key
Salted_Pork
Posts: 27 Joined: Thu Mar 07, 2024 8:03 pm
CNC Control System Serial Number: 54453804251C-0118247882
Post
by Salted_Pork » Sun May 19, 2024 2:04 pm
spikee wrote: ↑ Fri May 17, 2024 2:02 am
Open the oscilloscope function of your servo. Measure the frequency of the ossilation. And use the built in notch filter to remove that oscillation.
At least, that is how it works wirh delta servos.
All indications, to me are servo tuning related.
Leadshine does not seem to have a notch filter option :/
Salted_Pork
Post
by Salted_Pork » Sun May 19, 2024 2:08 pm
suntravel wrote: ↑ Sun May 19, 2024 2:34 am
Do you have a manual from the servo driver?
Here’s the manual. Not finding the same terms you have mentioned in the adjustable parameters. Mind taking a look?
ES-DHhm_V1.3.pdf
(2.07 MiB) Downloaded 15 times
spikee
Posts: 58 Joined: Thu Feb 01, 2024 5:34 am
Post
by spikee » Sun May 19, 2024 2:56 pm
that servo drive, at least to me seems extremely basic.
No filters, very basic parameters etc. Could email leadshine, perhaps they have a fix. But i kinda doubt it.
Posts: 2294 Joined: Thu Sep 23, 2021 3:49 pm
Post
by suntravel » Sun May 19, 2024 4:33 pm
Try to change PA_00 - PA_02 to reduce vibration.
Posts: 2333 Joined: Fri May 24, 2019 8:34 am
Post
by ShawnM » Sun May 19, 2024 5:46 pm
If you have the ProTuner software and the RS-232 cable you can manually tune the drive for better performance. The procedure is in the manual.
Houseman303
Post
by Houseman303 » Tue May 21, 2024 2:42 pm
Pa-04 and Pa-10 for Stiffnes (Holding Torque)
Salted_Pork
Post
by Salted_Pork » Wed May 22, 2024 1:50 pm
Update:
Adjusting the above parameters did not seem to help.
Did another troubleshoot session.
Smooth motion by hand with gear connected, but not motor (no Vibration):
https://photos.app.goo.gl/11kaUWE1i4yTaY519
Belt disconnected, rotating motor (small vibration only at certain feed rate):
https://photos.app.goo.gl/KvT87rs54SSmtHZx6
Belt connected, jogging machine (full Vibration):
https://photos.app.goo.gl/vE9vN1WLVgmAeuKD6
https://photos.app.goo.gl/igBNvvA96uY9jfiq7
Does this mean its just the motor? and when the belt is connected, the vibration is amplified? Vibration is only at lower motor speeds.
Would gearing the motors to spin faster be a good solution?
Mitchell
Post
by suntravel » Wed May 22, 2024 1:55 pm
Salted_Pork wrote: ↑ Wed May 22, 2024 1:50 pm
Mitchell
If the motor is only vibrating at very low speed, gearing would avoid this low speed on the motor, so it will run smooth while cutting with the same feedrate it is now vibrating.
