CSR on acorn 5.1
- CNC Control System Serial Number: none1862e483d9b6-0319203082
CSR on acorn 5.1
How do I change the CSR to correct the y axis? so the angle is along Y.
Re: CSR on acorn 5.1
Section 4.4 in the Mill Operator's Manual.
You can select the direction for the measurement points, but the rotation symbol will always appear on the X DRO.
are you talking about lining up a rotated part/stock to the Y axis?
OR fixing a machine that is not square Y to X?
