I am considering using the Centroid Wired MPG (PN 11069) with a Galil motion controller to jog an X-Y stage in an SEM chamber. I have used this MPG with an Oak controller in the past and like it.
But I could not find a manual or wiring diagram showing how the encoder and the switches are pinned out.
Can somebody please point me to the appropriate document?
Wired MPG pinout
Re: Wired MPG pinout
A pinout for the 28-pin connector is attached.
The wire noted wire colors are for the MPG coil cord (or they were when I first drew this; I have not verified it in recent years to see if production changed).
I believe the DC Common (WHT wire, pin 22) is used as the common for the two selector switches.
- MPG28PinConMPU11.pdf
- (23.34 KiB) Downloaded 23 times
- CNC Control System Serial Number: A900196
Thanks for the information. Sorry for the late response.
