Question for those running water-cooled spindles
I was surprised to be told by the manufacturer that the water is supposed to be removed from the water lines and spindle every day. I had assumed that the spindle water circuits are made of something that's not going to degrade with exposure to distilled water. I even wonder how beneficial the removal is since moisture will still be present. I suspect the manufacturer says this to cover themselves, reducing the chance of leaks by 2/3, based on an 8-hr work day, but I'm just theorizing. What have you guys heard about this, and do you guys clear the lines every day?
Previous hobby, building hard core sports cars. See http://midlana.com/ and http://kimini.com/
- CNC Control System Serial Number: 20D7787C45AB-0819226470 - 98F07B6F97F8-0623237343
Re: Question for those running water-cooled spindles
What spindle do you have?
I have one of the Chinese 2.2Kw Water Cooled spindles with a closed loop cooling set up and never remove the coolant. But I don't use plain water because it will grow things over time.
I use car antifreeze, but you could also use RV antifreeze (its less toxic) or distilled water with a biocide in it.
Thx
Ian
QueenAnt Pro V2 - CNC Router - https://photos.app.goo.gl/kg7CSvJsrAvAgRs26
MPNC - CNC Router - https://photos.app.goo.gl/ees2SER6C2Aw8AJ89.
Ian
It's Chinese (Jianken) and yeah, I'm running distilled water and "Water Wetter."
Jianken is a reasonably well regarded make from what I have seen in hobby circles. Not sure what the water wetter is but you want a biocide to prevent growth and a corrosion inhibitor of some sort. I use antifreeze because its relatively cheap, premixed, easily available and designed to run in systems made up of dissimilar materials.
Thx
Ian
Ian
I don’t use water cooler spindles anymore but my first two machines had them. I also ran antifreeze in mine, I used the 50/50 premixed, DexCool with no issues at all.
Water Wetter is a surfactant to reduce the surface tension of the water/ coolant allowing it to "flow" over surfaces better and therefore increases heat transfer.
