original part
Filardo
Re: original part
Post by Filardo »
suntravel wrote: Mon Nov 20, 2023 2:08 am Use Feed Hold
Sorry I did not understand
Désolé j' ai pas compris
Filardo
Re: original part
Post by Filardo »
Ok vous voulez parler de ce bouton
Re: original part
Filardo wrote: Mon Nov 20, 2023 1:49 am
cnckeith wrote: Fri Nov 17, 2023 5:23 pm
Filardo wrote: Fri Nov 17, 2023 12:36 am hello why with each tool change I have to redo my Z zero of the part even though I have just measured the tool
not if you maintain a tool library.
the old mill training instruction video shows this.
Ok thank you very much for your answer
I have another question about advances. When I lower the advance button to zero %, the advances continue to advance.
Is it possible to have no movement at zero %?
Ok merci beaucoup pour votre réponse
J' ai une autre question concernant les avances. Quand je baisse le bouton des avances a zéro % les avances continue d'avancer
Est il possible d'avoir aucun mouvement à zéro %?
yes that setting is in the Wizard. % for feed hold invoke.
Filardo
Re: original part
Post by Filardo »
cnckeith wrote: Mon Nov 20, 2023 9:50 pm
Merci pour votre réponse
Filardo
Re: original part
Post by Filardo »
But I have to change a parameter If yes, what is the parameter number?
Re: original part
The manuals that Centroid put together are amazing!
"15.3.93 Parameter 146 — Feed Hold Threshold for Feed Rate Override
This parameter sets the lowest value permitted as the feed rate override percentage before feed hold is engaged. Feed hold will be released when the override percentage is greater than this value."
That is if you want feed hold to automatically engage as you lower the feed rate override. You can manually engage feed hold at any time by pressing the feed hold button on the VCP.
Filardo
Re: original part
Post by Filardo »
tblough wrote: Thu Nov 23, 2023 8:47 am The manuals that Centroid put together are amazing!
Merci beaucoup
