hi
I have a job running on my lathe cnc12 lathe pro ,and watch the program run after clicking the graph button .
is there a setting I can click so I get the rpm value on the graph screen ,I only see it on the g code screen
thanks
rpm on graph?
Re: rpm on graph?
Update to 4.80 then you will have actual and programmed rpm displayed in the RTG.
Re: rpm on graph?
If only some of these enhancements would filter down to the servo software. /*sigh*/
Re: rpm on graph?
its on the way.. we are porting and merging now!
