Parameter for relief on turn cycle
Scary
Post by Scary »
Hi all, does anyone know what parameter changes the amount of tool retract on a simple "turn" cycle in intercon. Profile is working fine but I am chasing a little more relief on the turn cycle to allow me to unhook chips sometimes. None of the parameters i have found so fad seem to affect it
Re: Parameter for relief on turn cycle
Clearance Amount in ICN Setup page.
Scary
Post by Scary »
I have tried that setting but it doesn’t seem to change it any. The profile settings change behaviour but the clearance setting doesn’t behave any differently if you change the numbers. Strange……. :shock:
Scary wrote: Tue Jul 05, 2022 6:24 am I have tried that setting but it doesn’t seem to change it any. The profile settings change behaviour but the clearance setting doesn’t behave any differently if you change the numbers. Strange……. :shock:
ok I just tested that Turn in Intercon produces G90 cycles.
They just return to the start position, so there is no escape amount.
Scary
Post by Scary »
That sucks! Oh well, back to using profile for everything. At least you can chamfer/radius corners in profile
Profile is better anyway, especial if you have finish amount in Z ;)
