Ether1616 Outputs not working <self resolved video>
mrp192
CNC Control System Serial Number: 3699, 3788
Post by mrp192 »
Hey everyone,
This is something I have been trying to figure out for awhile now and I am too the point where I need to ask for help. I have my spindle cooling fan on one of the Ether1616 outputs and when I either run a job or force the output nothing happens. It is as if my ether1616 did not get the command. I know the Ether1616 is working because the inputs are working.
report_E415F6F96E67-1005203788_2021-11-06_19-05-47.zip
(703.25 KiB) Downloaded 65 times
RogDC
Re: Ether1616 Outputs not working
Post by RogDC »
Is that the correct relay board for the Ether1616?
Can you attempt to force any of the other outputs from the Ether1616 into the correct state?
mrp192
Post by mrp192 »
RogDC wrote: Sat Nov 06, 2021 10:44 pm Is that the correct relay board for the Ether1616?
That is the relay board that came with the Ether1616. No I cannot force any other outputs for the Ether1616.
TheKitMill
Post by TheKitMill »
Hi It looks like you have the Relay Board hooked directly to the Acorn Board and you are connected to output 8. Try forcing output 8 and see if it turns on the relay you are connected to.
Remember outputs on the Ether1616 start at 33:
Output 1 on Ether1616 with A0 address = CNC12 output 33
Output 2 on Ether1616 with A0 address = CNC12 output 34
Output 3 on Ether1616 with A0 address = CNC12 output 35
etc..
mrp192
Post by mrp192 »
TheKitMill wrote: Sun Nov 07, 2021 10:22 am Hi It looks like you have the Relay Board hooked directly to the Acorn Board and you are connected to output 8. Try forcing output 8 and see if it turns on the relay you are connected to.
I have my E1616 mounted under my Acorn. I have DC circuits on the left and AC on the right.
mrp192
Post by mrp192 »
tblough wrote: Sun Nov 07, 2021 10:57 am Remember outputs on the Ether1616 start at 33:
etc..
Ill try that but but even if I run code it still doesn't turn on.
mrp192
Post by mrp192 »
I'm an idiot and I figured it out.
Upnorth
Post by Upnorth »
Good you made a video with the solution. Nice to have someone go the extra mile on that. It might help someone in the future.
