My Sherline 5400 mill with Acorn control build
BillB
Re: My Sherline chucker lathe & 5400 mill with Acorn control build
Post by BillB »
Here are a couple screenshots of those log pages, just a couple random pages, looks like lots of errors but I’m not sure what I’m looking for exactly.
When I set up PC I updated everything btw
BillB
Post by BillB »
Do you want me to post the entire report to the thread? Can I upload it somehow?
Those are PC/MPU resends. They need to be corrected. We need to determine if it's the PC or EMI noise.
On Acorn, unplug everything except power from the provided power supply and the provided Ethernet cable.
Start CNC 12 and leave it run. Check your error logs
It would be good if you can set Acorn to DB25 bench test for this test. Make sure you are set up for simple home. In CNC12, press cycle start to set home. DRO's should be zeroed.
Then load any program and press cycle start to run it
Afterwards, look at your error logs for any PC/MPU resends.
Did you update the drivers on that PC?
I would appreciate if you would upload your report file.
You click on FULL EDITOR & PREVIEW button.
Then click on the Attachments button under the message box where you type your message Point to the file on your computer.
You need to learn to do this as a fresh report is required when asking for support on this forum.
BillB
Post by BillB »
I did update drivers when I set up the computer as per CNC PC set up steps. Your video.
You asked me to unplug everything except Ethernet cable and power supply but then you said to make sure I have simple home set in the wizard whitch I did then wrote to Acorn. But now because the limit switches are unplugged I get this error. I can not 0 the DROs out because home switch is tripped cuz it’s unplugged. Should I delete home all from inputs?
How to proceed to get report done?
You need to load a DRIVE type. Benchtest DB25.
I have mentioned several times how to create the report.
From the main CNC12 Screen
Press F7 Utility
Then from the Utility Screen press F7 Create report.
Maybe the video in this post will help:
viewtopic.php?f=63&t=943
You need to figure out the PC/MPU resends. Those are ethernet communications errors between the PC and Acorn
BillB
Post by BillB »
Marty Here is my report.
I hope this is good to get what we need to know. I had to turn off Home all, because now when I hit cycle start the 1st axis starts to move and keeps moving as it is searching to hit a limit switch. It keeps going on forever until I physically hit one of the switches. after I hit this switch the DRS will not zero out. I changed settings for max travels and it keeps going on beyond the set limit? SO I just turned it off.
report_6433DB044D1E-0623214856_2021-09-15_18-16-29.zip
(618.63 KiB) Downloaded 54 times
BillB
Post by BillB »
I was able to get the report from Sherline so gonna load it up and see what happens.
BillB
Post by BillB »
Good news, got motors turning with Sherlines drive configuration.
BUT can not get machine homed and DROs zeroed out. When hitting cycle start to home I’m getting “home switch tripped!!! please clear before homing. Press cycle cancel to end homing.
John has homing “1st 2nd 3rd Axis home ok” in inputs
As said before limit/home switches are working when pressed.
Is there something wrong with my wiring for the switches, It's wired as per S14954 but I've added the terminal blocks. Cleaned up the wires so you could more clearly trace them.
Please Post a NEW fresh report.
How do you have your home switches configured? Are they on series and you are using HomeAll?
