Macro for putting last tool used away when job complete.
seven7thirty30
CNC Control System Serial Number: 3447
Post by seven7thirty30 »
Hello, all. I have an ATC system on my router that I've been setting up and I'm looking for some advice on how I can setup a macro or edit my current macro to put the last tool away that was used during a job when the job is complete. Currently, when the job is complete the system returns to Z zero and the spindle shuts off. I have to manually remove the tool, but then the system thinks that the tool is still in the spindle. I want to be able to put the tool back so that I can swap out tools and make the changes via the bin numbers for the next job since my tool rack is limited to 6 tool holders. I would like the machine to put the tool away then return to home (I use proximity switches). I thought about editing the "Park" macro to do this. Any advice is appreciated.
Here's my current ATC macro that works well.
mfunc6.mac
(1.45 KiB) Downloaded 78 times
Gary Campbell
Re: Macro for putting last tool used away when job complete.
Post by Gary Campbell »
T0 M6
G30 P4
Where return P4 is set to my desired park location
seven7thirty30
Gary Campbell wrote: Sun May 16, 2021 12:12 pm T0 M6
G30 P4
You added this to your mfunc6 or your park?
Gary Campbell
I modified my park.mac as above. This allows me to change the park location easily when needed
seven7thirty30
I'll try it. I'm assuming that when you press "Park" it puts the tool away then moves to the park location, is that right?
