4.6 Won't Update From Saved Report
Mkelcy
Post by Mkelcy »
I've been attempting to update to 4.6 Router from 4.5 using a report to restore my settings. I followed the procedure in the updating to 4.5 video, but I don't get the screen in the Wizard at 10:27 of the video, that gives me the option to update the wizard. 4.5 report that I'm trying to use attached.
report_7804732BCC31-0227191699_2021-01-30_14-56-35.zip
(714.98 KiB) Downloaded 127 times
mrp192
CNC Control System Serial Number: 3699, 3788
Re: 4.6 Won't Update From Saved Report
Post by mrp192 »
I noticed this also. Some things did update but not everything.
You may be better off hand copying your settings over to 4.6
Hopefully you had screen shots of all your Wizard settings. It took me about 15 minutes a machine.
Mkelcy
Post by Mkelcy »
Marty: I would do that, but I don't know how to edit the Axis drive type - I can get into the "custom" screen" but don't know how to make changes. I'm using a step rate of 200,000 and 16,383 steps/revolution.
Mkelcy
Post by Mkelcy »
While I'm at it, there doesn't seem to be a SlavedHomeInput in 4.6. What do I use instead?
SlavedHomeInput is under the HOME drop down on the Input screen:
You also have a BUNCH of Communications Errors. And Error Initializing MPU
F7 Utilities, F9 Logs, F1 Errors.
Did you address this?:
(4) 01-08-2021 17:16:25 946 PC resending # 116377
(4) 01-08-2021 17:16:25 944 MPU requested resend # 2651
(4) 01-08-2021 17:16:25 946 PC resending # 116416
(4) 01-08-2021 17:16:26 944 MPU requested resend # 2652
(4) 01-08-2021 17:16:26 946 PC resending # 116426
(4) 01-08-2021 17:16:26 946 PC resending # 116476
(4) 01-08-2021 17:16:27 944 MPU requested resend # 2653
(4) 01-08-2021 17:16:27 946 PC resending # 116535
(4) 01-08-2021 17:16:30 944 MPU requested resend # 2655
(4) 01-08-2021 17:16:30 946 PC resending # 116596
(4) 01-08-2021 17:16:30 946 PC resending # 116644
(4) 01-08-2021 17:16:31 944 MPU requested resend # 2657
(4) 01-08-2021 17:16:31 946 PC resending # 116706
(4) 01-08-2021 17:16:31 944 MPU requested resend # 2658
(4) 01-08-2021 17:16:31 946 PC resending # 116762
(4) 01-08-2021 17:16:33 944 MPU requested resend # 2659
(4) 01-08-2021 17:16:33 946 PC resending # 116797
(4) 01-08-2021 17:16:39 944 MPU requested resend # 2660
(4) 01-08-2021 17:16:39 946 PC resending # 116841
(4) 01-08-2021 17:16:41 944 MPU requested resend # 2661
(4) 01-08-2021 17:16:41 946 PC resending # 116902
(4) 01-08-2021 17:16:43 944 MPU requested resend # 2662
(4) 01-08-2021 17:16:43 946 PC resending # 116953
(4) 01-08-2021 17:16:43 944 MPU requested resend # 2663
(4) 01-08-2021 17:16:43 946 PC resending # 116987
(4) 01-08-2021 17:16:46 944 MPU requested resend # 2664
(4) 01-08-2021 17:16:46 946 PC resending # 117047
(4) 01-08-2021 17:16:47 944 MPU requested resend # 2665
(4) 01-08-2021 17:16:47 946 PC resending # 117091
(4) 01-08-2021 17:16:48 944 MPU requested resend # 2666
(4) 01-08-2021 17:16:48 946 PC resending # 117143
(4) 01-08-2021 17:16:49 944 MPU requested resend # 2667
(4) 01-08-2021 17:16:49 946 PC resending # 117172
(4) 01-08-2021 17:16:49 946 PC resending # 117188
(4) 01-08-2021 17:16:56 944 MPU requested resend # 2668
(4) 01-08-2021 17:16:56 946 PC resending # 117190
(1) 01-08-2021 17:28:38 204 Exiting CNC...Normal Exit (66)
(1) 01-14-2021 14:03:59 199 CNC Started
(1) 01-14-2021 14:04:05 CNC12 Acorn Mill v4.50
(4) 01-14-2021 14:04:07 9033 Reset Initiated, Press Reset to Clear
(1) 01-14-2021 14:04:23 Created Weekly Report
(4) 01-14-2021 14:04:51 4032 Reset Cleared
(1) 01-14-2021 14:04:56 FAST_JOG_SELECTED
(4) 01-14-2021 14:05:11 5038 SPECIFIED SPIN SPEED < MIN SPIN SPEED
(1) 01-14-2021 19:08:51 204 Exiting CNC...Normal Exit (66)
(1) 01-16-2021 11:52:45 199 CNC Started
(1) 01-16-2021 11:52:52 CNC12 Acorn Mill v4.50
(4) 01-16-2021 11:52:52 9033 Reset Initiated, Press Reset to Clear
(4) 01-16-2021 11:52:56 4032 Reset Cleared
(4) 01-16-2021 11:52:59 5038 SPECIFIED SPIN SPEED < MIN SPIN SPEED
(1) 01-16-2021 11:53:04 FAST_JOG_SELECTED
(1) 01-16-2021 11:53:14 SLOW_JOG_SELECTED
(1) 01-16-2021 11:56:24 FAST_JOG_SELECTED
(1) 01-16-2021 14:48:51 204 Exiting CNC...Normal Exit (66)
(1) 01-18-2021 17:38:16 199 CNC Started
(1) 01-22-2021 8:24:32 102 Error initializing CPU...cannot continue.
(1) 01-22-2021 8:24:34 201 Exiting CNC due to a known error (63)
(1) 01-22-2021 8:43:10 199 CNC Started
(1) 01-22-2021 8:43:17 CNC12 Acorn Mill v4.50
(4) 01-22-2021 8:43:18 9033 Reset Initiated, Press Reset to Clear
(1) 01-22-2021 8:43:34 Created Weekly Report
(4) 01-22-2021 8:47:33 4032 Reset Cleared
(4) 01-22-2021 8:47:37 5038 SPECIFIED SPIN SPEED < MIN SPIN SPEED
(4) 01-23-2021 11:30:06 9031 DRIVE FAULT!
(1) 01-23-2021 17:44:00 204 Exiting CNC...Normal Exit (66)
(1) 01-27-2021 15:39:46 199 CNC Started
(1) 01-27-2021 15:39:52 CNC12 Acorn Mill v4.50
(4) 01-27-2021 15:39:52 9033 Reset Initiated, Press Reset to Clear
(4) 01-27-2021 15:39:56 4032 Reset Cleared
(4) 01-27-2021 15:40:06 5038 SPECIFIED SPIN SPEED < MIN SPIN SPEED
(1) 01-27-2021 15:53:30 FAST_JOG_SELECTED
(1) 01-27-2021 16:44:19 204 Exiting CNC...Normal Exit (66)
(1) 01-27-2021 19:52:22 199 CNC Started
(1) 01-29-2021 13:07:17 102 Error initializing CPU...cannot continue.
(1) 01-29-2021 13:07:19 201 Exiting CNC due to a known error (63)
(1) 01-30-2021 12:21:13 199 CNC Started
(1) 01-30-2021 12:21:20 CNC12 Acorn Mill v4.50
(4) 01-30-2021 12:21:21 9033 Reset Initiated, Press Reset to Clear
(1) 01-30-2021 12:21:40 Created Weekly Report
(4) 01-30-2021 12:21:40 4032 Reset Cleared
(4) 01-30-2021 12:21:40 9033 Reset Initiated, Press Reset to Clear
(4) 01-30-2021 12:21:41 4032 Reset Cleared
(1) 01-30-2021 12:22:23 Creating report...
(1) 01-30-2021 12:22:25 Saved report to C:\Users\MyPc\Documents\Centroid Documents\report_7804732BCC31-0227191699_2021-01-30_12-22-22.zip
(1) 01-30-2021 12:33:44 204 Exiting CNC...Normal Exit (66)
(1) 01-30-2021 12:34:32 199 CNC Started
(4) 01-30-2021 12:34:36 9039 Software Exited, Cycle E-Stop/Reset to Continue
(1) 01-30-2021 12:34:39 CNC12 Acorn Mill v4.50
(4) 01-30-2021 12:34:39 9033 Reset Initiated, Press Reset to Clear
(1) 01-30-2021 12:35:00 204 Exiting CNC...Normal Exit (66)
(1) 01-30-2021 14:55:40 199 CNC Started
(1) 01-30-2021 14:56:10 CNC12 Acorn Mill v4.50
(4) 01-30-2021 14:56:11 9033 Reset Initiated, Press Reset to Clear
(1) 01-30-2021 14:56:36 Creating report...
DId you try any of the Beta's with Router in them?
If not, since you are coming from Mill, I don't think your license is going to work with Router and you will have to upgrade to a Router License.
Mkelcy
Post by Mkelcy »
Marty you got me thinking about mill versus router license. I tried installing 4.6 mill just now, and it worked perfectly; I had been trying to install 4.6 router (I have a router). The issue is pretty clearly that I didn't know I had to have a router license. Oops.
see the Acorn page for explanation, Router CNC12 requires a Router License. there is a reduce cost Router license for a limited time if you have a pro mill license file. (CNC12 Mill works with Mill License file, CNC12 Lathe works with Lathe License file, CNC12 Router works with Router License file)
https://www.centroidcnc.com/centroid_di ... oller.html
"All the CNC features of Mill Pro but with a Router specific Virtual Operator Control Panel and the corresponding Router specific macros.
If you previously purchased Mill Pro you can for a limited time upgrade to Router Pro (#15077) for $79
If you previously purchased Mill Digitizing Bundle you can for a limited time upgrade to Router Digitizing Bundle (#15078) for $79"
i downloaded your report.zip and used 'restore report' and started that Wizard and did get the update Wizard message, i clicked update Wizard and then "write settings to cnc control" and everything updated just fine.
