CNC12 v4.18 Acorn Spindle Fault
johnnw
CNC Control System Serial Number: 1211181414
Post by johnnw »
I am confused about the correct wiring of a HuanYang VFD to Acorn board.
After searching the forum I find a post where Marty says "There is an error in the HY Schematic, use FB & FC".
Then I checked the following 2 schematics:
S14898-ACORN_rev3 HUAN YANG VFD.pdf dated 180427 shows VFD FA goes to Com and FB goes to DriveOK (Input5 on the Acorn board).
While S14984-ACORN_rev4_HUAN_YANG_VFD.pdf dated 191022 shows VFD FA going to Spindle OK (again Input5 on the Acorn) and FB going to Com.
This is quite a difference.
I have wired my system using the latter diagram: FA ==> Input5 and FB ==> Com but this gets me a Spindle Fault message.
I would try the other diagram but I'm concerned I would screw up Acorn.
The VFD/Spindle works fine in manual mode.
Anybody with a HuanYang VFD and Acorn care to suggest what I should try?
John
johnnw
Re: CNC12 v4.18 Acorn Spindle Fault
Post by johnnw »
my edit
sorry, forgot attach the report file
John
report_F045DA76C0F3-1211181414_2020-03-02_16-55-02.zip
(284.49 KiB) Downloaded 66 times
johnnw
Post by johnnw »
Never mind. Palm to forehead.
I was ignoring the "Rev 3" and "Rev 4" description in the titles of the schematics.
Just realized I have a Rev3 board and should probably use the older diagram.
I will try it in the morning.
John
