I set up ZRI on our lathe that has two dyn4 drives. It seems to be finding the reference signal during the homing sequence on both axis. I can easily verify this by unplugging the ZRI signal from the drive and watching the homing sequence move indefinitely. The issue is when homing the machine again it does not hold the same zero. We can run a program to do a skim cut, rehome the machine and run the program again and it will be significantly off in X by nearly 0.2". I checked if there were lost steps in both axis and found nothing. The homing speed is set to 40ipm on both axis @ 8000 steps/rev. Anyone have an idea of what could be causing this?
M92/X L1
M105 /X P-3 F3 ;Move X plus at 3ipm until input 3 closes
M26/X
M92/Z L1
;G0 Z 2
M105 /Z P-4 F3 ;Move Z minus at 3ipm until input 4 closes
M26/Z
M35 ;Open Turret
G4 P0.5 ;Pause
M92/A L1
M26/A
;G0 A -.3 ; Disengage fom worm gear for Turret Lock, Worm Gear has deadspace between tools to prevent turret lock from pushing on the gear.
M26/A
M27 ; Turn on Turret Lock
So after some testing and logging I am find that the repeatability significantly increases at lower homing speeds. At 3 IPM the repeatability rate is fairly low. I can get it to zero at the same home location 2 out of 10 times. At 0.8 IPM ZRI homing the repeatability is at zero 10 out of 10 times. I'm tempted to lower the steps/rev and test.
M106 /Z P3 F10 ;Move Z plus at 10 in/m until input 3 opens
M105 /Z P-3 F.5 ;Back Z off switch slowly
M105 /Z P-4 F.5 ;Move Z minus at .5 in/m until ZRI input 4 closes
M26 /Z ;Set Z home here
Thanks for the tip its working much better now. Looks like if you have the homing speed set to high it overtravel's the switch and causes issues finding the same ZRI reference every time. Slowing it down lets you hit the switch and the same ZRI reference point more accurately.
If your switch is too close to the marker pulse that may be contributing to the problem. The solution is to rotate the motor shaft 180 degrees or so and reconnect to the machine (assuming direct drive) if belt drive similar. Or move the switch.
I actually had to do this on the X switch. I moved switch stop just slightly to fix it. It was bouncing back and forth between two different markers. Moved the stop slightly and its hitting the same marker every time now.
