Change the .txt to .cps for fusion to recognize it.
Feedback is welcome.
Use at your own risk.
I have not tested this live.
Clay
Fusion 360 lathe post processor ready for BETA
- Centroid Acorn 12_27_17.txt
- (51.29 KiB) Downloaded 117 times
Clay
near Winston-Salem, NC
Re: Fusion 360 lathe post processor ready for BETA
Has anyone tested this yet?
Clay
Anyone?
Clay
Not quite there yet Clay....your efforts won't be for nothing!
Have you tested it well?
Unfortunately, I don't have a good way to physically test it. However, I I took a Fanuc Post processor and modified it so CNC12 would read it without any errors. Then I read through what I produced and compared it to Intercon.martyscncgarage wrote: ↑Wed Jan 10, 2018 8:42 pmNot quite there yet Clay....your efforts won't be for nothing!
Then I simulated it on CNC12 and it graphed what I expected.
It's essentially a Fanuc post with some data changed as in m codes that were the different number, and planar g codes that are unnecessary for CNC12 and created errors. I compared the Centroid output to the Fanuc output as far as actual feed rates and positions, and it was identical.
So that's where it is. I see no reason it would crash anything, but I can't say it always generate clean code.
At this point, I think it's the best post processor available for Fusion 360 and Centroid turning, and also, the only one.
![Laughing :lol:](./images/smilies/icon_lol.gif)
Clay
Clay
- CNC Control System Serial Number: C8FD19F23AFF-0213180659
Appreciate your work on the post file. I want to test it out, but I'm setup for diameter mode in CNC12 and I can't find any way to change Fusion 360 from radius to diameter mode? I've read all the google articles I can find, but nothing really seems to show that it can be done. So to use Fusion 360 Cam, will I have to run CNC12 in radius mode?
Decided my first CNC run was gonna be a bishop instead of a pawn.....LOL....gotta be different.
Oh yeah, noticed when I tried to post with mist turned on, the post processor would not run (well, it ran, just didn't create proper gcode).
Edit, for some reason it was because I had mist turned on. Using mist causes an error on the post running properly.
Here is a lot more info on the stuff I've found with this post file. I started a new thread, as originally I thought it was my CNC12 setup. Now I think it's either the post file or a setting I have wrong in Fusion CAM.
viewtopic.php?f=60&t=1856
