Bridgeport Interact 412
- CNC Control System Serial Number: 3639
Re: Bridgeport Interact 412
Outstanding. Acorn running a VMC. Can you summarize the build, drives/motors, VFD/Spindle Motor
Ok here is the info on the build. The spindle motor is the original 5.5 KW Fanuc. The spindle is ran with 220 single phase with a Delta C2000 VFD with a PG01L Encoder Feedback Card for the spindle orientation. The Servos and Drives are Bergerda Automation Technology. The Z axis is a 1.5 KW and the X And Y are 1.0 KW 220 volt AC. This is set up with Acorn and a ether 1616 I/O expansion kit.
- CNC Control System Serial Number: 102139, 20D7787D9392-0817226460
Are you using the preprogrammed spindle on(green) off(red) buttons on the default VCP.
And are you using them to turn one OUTPUT on and off that controls a contractor or similar?
I know this is pretty basic but no o seems to be able to set back to this level of simplicity and show me how to do it.
Thanks in advance
Thanks in advance
Yes I am using the on off buttons for manual spindle control. The way I have it set up it is coming from the 0-10 volt terminals on the acorn board to the 0-10 volt terminals on the VFD.
The only essential changes from the factory PLC program were:
1) Provide a spindle-run signal to accompany the spindle-orient signal (required by the Delta C2000 drive)
2) Manage carousel advance/retract with a single-coil spring-return solenoid, instead of the usual two-coil detented solenoid
can i use this pic on the Acorn web page?
and do you have any others?
Hi Keith here are some more Pics of the Machine. Yes you may use them on the web page. I do not know why all these came out side ways. Can you rotate?
Thanks John
Thanks John
Hi Keith here are some more pics. Yes you can use them on the web page.
Thanks John
Thanks John
- CNC Control System Serial Number: many
beautiful job !
