10hp spindle 24,000 rpm
3hp 9 drill head
8 tool unbrella ATC
1.8KW DYN SERVOS X/Y
Centroid Oak with 2 1616 plc expansion boards
M400 operator console
Wireless MPG
5X10 TABLE
Customer using table to mill lead sheets used to line xray-catscan, MRI equipment
LINK TO BUILD PHOTOS FINISHED PRODUCT AT END
https://photos.app.goo.gl/KEPZRRuZK7KZEhwZA
Omnitech Selexx Pal 2003 Router
Re: Omnitech Selexx Pal 2003 Router
sweet! what a project!
I've looked at a few of those at various auctions, they are nice machines. I'm looking for a 5x10 now for a retrofit.
- CNC Control System Serial Number: 1218120647
Anderson make nice machines. This one look like its new.
How have you incorporated the "V" drill bank.
I converted an SCM pod and rail cabinet machine to Centroid Oak. It had Yaskawa servos so it wasn't so difficult. I wired it so that I can use the drills in the "V" drill bank individually. Same with the horizontall drills and saw. I never bothered to make them work together as seperate tools registered to one another.
I never learned to write the code that gives a tool a different XY offset from another tool.
We're you able to achieve it. Was it difficult.
Rich
Rich
