Finished the lathe and can start to make some parts now.
Here is a complete process how I make parts with the lathe:
Hobby lathe with AC servos
Re: Hobby lathe with AC servos
Absolutely fantastic!!! A couple questions; what is the device you are using for tool touch off? and what is the tool post?
You are a bad influence - now I need a cnc lathe 9-)
Bill
Bill
Tool Touch Off is a cheap chinese 3D probe with NPN circuit and a self made Tip.
Tool post is a solid block cast iron with a Multifix quick change system on top.
Multifix is very popular in Germany and Swiss on manual lathes.
Do you touch the diameter and the end of the probe tip?
I found the Multifix post...I'll have to save my pennies 9-)
Yes, acorn lathe dose this in one go if you choose Measure X and Z auto.
There are lot of copies from Multifix on the market, chinese ones are cheap, good ones from AXA Germany have perfect quality for a few more bucks.
Is the probe a touch probe with a different stylus?
yep with a 10x2mm flat tip.
The lathe works as a fast saw also....
When you say that you have servo motors. Do you mean stepper motors with encoders "hybrid steppers"? I have a milling machine with servo motors but they are DC and i don't think that they will work with the Acorn control board.
Prior to my conversion I bench tested Acorn using the original DC motors and Gecko G320 drivers. The problem with the Geckos is they are limited to 80 VDC.. among other limitations.
