Re: 11x26 Import Lathe Conversion to Acorn
Posted: Wed Nov 06, 2019 9:32 am
Steve,
Thank you for sharing, amazing. I'm about to get started on an import 10x22 lathe conversion (G0602), was wondering a few things if you dont mind.
1. Did you use angular bearing blocks on both ends of the ballscrews (for x and z)?
2. At the bearing block ends of the ballscrews, how did you have them machined? Thread-bearingsurface-Thread? so that you fix the ballscrew end to the bearing block.
Chai from linearmotionbearings2008 is asking how I need the ends machined.
Any advice is appreciated, Best.
Daniel
Daniel
