First test router retrofit using acorn and cnc12
Re: First test router retrofit using acorn and cnc12
wow! fantastic..looks like a million bucks!
E415F6F70BC3-0318203049
+1 That is seriously nice work Noel
Hope this helps
Nigel
Nigel
- CNC Control System Serial Number: (2669)
connecting I/Os from Acorn and Ether1616 for operate multi spindle drill head, now is done.
this is a test of a simple g code program that embedded macros for multi spindle drills under Mcode representing mfuncXX.mac
here are the multi spindle drills running one by one or sets of two and three, they can be configured by just changing the Mxx number that represent every drill.
in every macro is determined the offset position for that drill from origin, followed by the G91 it position that drill where it needs to be.
so when the Mxx code is called in the program each drill search it's position. that is the best way i could find when using a cad/cam software like Vcarve.
i laso had to create a new post procesor to generate drill programs separate.
maybe some one has a better solution for this operations?
nice and clean! thanks for posting.noel-nogal wrote: ↑Tue Nov 16, 2021 1:44 pm acorn04 (2).jpg
right on! production mode!!
Mr. keith
i am trying to unlock the work cordinates system from #7 to #18 but they just do not unlock with the F2 key or the button, do you know how to do this, i need enter values for setting my multi spindle drills, i have 10 drills and i am using wcs from G55 to G59 assigning each drill offset on each wcs, but i need the extra ones to assign the other 5 drills.
best regards
Noel
best regards
Noel
Please post a fresh report.zipnoel-nogal wrote: ↑Thu Dec 23, 2021 5:36 pm Mr. keith
best regards
Noel
