Under v4.12 I was able to run a maximum of 300 IPM on my knee mill with DYN4 servo drives. When I try to change maximum speed setting in the wizard for v4.14, it will not allow me to enter 300 IPM, a pop-up window says only allow a maximum of 150 IPM is allowed. I am running the "free" version for setup, if that matters.
Is this a new limit?
150 IPM limit with v4.14? ( Resolved )
Re: 150 IPM limit with v4.14?
What are your current and previous pulse per second settings? The default has changed in case you missed it
I had to get everything setup and reboot the controller then go back and up my rapids.
Acorn powered CNC router
