V4.14 and DYN4 - MUST SET DB25 SECTION TO SCREW TERMINALS!
Posted: Sat Mar 16, 2019 11:00 pm
by jj80909
When upgrading to v4.14 and using DYN4 servo drives, you must select "Set to screw terminals" under the DB25 tab or your servo "enable" signals won't work and your step direction will be reversed.
Re: V4.14 and DYN4 - MUST SET DB25 SECTION TO SCREW TERMINALS!
Posted: Sat Mar 16, 2019 11:35 pm
by rangerboy347
yup that got me lol!
Posted: Sat Mar 16, 2019 11:39 pm
by slodat
I noticed the same.
Posted: Sun Mar 17, 2019 8:12 am
by Gary Campbell
Posted: Sun Mar 17, 2019 9:06 am
by slodat
There’s a lot of auto-magical in the background that isn’t explained or documented. For example using db25 step and direction and you must choose screw terminals so the enable outputs work.
Posted: Sun Mar 17, 2019 10:07 am
Centroid ran out of time to separate DYN2 and DYN4 in 4.14.
Next revision will have a separate radio button for DYN2 AND DYN4 (provided you use the screw terminals)
