Fusion 360 Post Processor for Acorn?
Posted: Sat Aug 25, 2018 10:42 pm
by rickwjenn
Started making some Fusion 360 CAM programs for my Acorn controlled mill.
I used the Fusion library post processor for "Centroid". Getting lots of errors and invalid codes ....
is there a specific post processor for Fusion 360 that outputs Acorn compatible code?
Re: Fusion 360 Post Processor for Acorn?
Posted: Sat Aug 25, 2018 11:10 pm
by ScotY
I ran into some problems (tool library issues) but, otherwise, the Centroid post works for me.
Posted: Sun Aug 26, 2018 11:00 am
by rickwjenn
Thanks - I will just go in and clean up the errors and keep trying!
Posted: Sun Aug 26, 2018 1:53 pm
by ScotY
Do you have any examples of the errors you’re getting? Maybe someone will be able to help more if they know. Oh, there is a menu/page somewhere in Fusion (I think when you go to post, it’s a window on the right side that you can scroll through...sorry, not home so can’t look at my PC) that has some selections you might want to review.
Posted: Sun Aug 26, 2018 8:21 pm
by rickwjenn
Thanks. I just very carefully did the post processing, selecting the Centroid configuration and all is good. Human error likely....
Posted: Mon Aug 27, 2018 10:55 am
by Dave_C
The mill post works for me with no errors. However, I have not had the same result with any of the three available Lathe versions. The best one still has to have some slight mods.
Dave C.
Posted: Mon Aug 27, 2018 11:23 am
by Sportbikeryder
I have modified posts for Fusion. While not completely straight forward, It is not too difficult.
User "Franco" has a Youtube video relating to a few tweaks he made to a post. I have modified a post to work with 4th axis positioning, as well as 5th axis positioning.
Posted: Mon Aug 27, 2018 2:41 pm
by rickwjenn
Thanks Sportbikeryder and Dave_C
I tried a little harder and go the Centroid post process to work. Built a 1400 block program that ran for 60+ mins (me being very cautious on speeds). Not a single error! I am good to go.
