Having successfully wired up my Acorn board and set up CNC12, I now want to install a touch-off plate (or TT-1 probe) to set Z zero. Where can I find information about wiring up something and then setting it up and using it in CNC12?
I have a 3-axis CNC machine (with a 2'x3' table) that will primarily be used for woodworking projects.
Z Touch-off plate setup
- CNC Control System Serial Number: 9884E3949BCE-0426180876
Re: Z Touch-off plate setup
check the acorn schematics for starters:-)
http://www.centroidcnc.com/centroid_diy ... matics.zip
Perfect. That will get me going. I saw the TT-1 Tool Touchoff schematic in the zip file. Just what I was looking for.
Thanks.
Thanks.
