Macro Question
cbb1962
Macro Question
Post by cbb1962 »
I know that there are no stupid questions; just stupid people. :roll:
Is there a tool like intercon to help create macros and debug them? I know that Mach3 had a tool that did this. Or is the CNC11 programmer's manual the best resource to learn?
Clint
Clint in NW Arkansas
Re: Macro Question
cbb1962 wrote: Tue Jun 12, 2018 9:29 am I know that there are no stupid questions; just stupid people. :roll:
Clint
Not that I am aware of Clint.
I would suggest posting what you are trying to do on the forum under its own thread.
cbb1962
Re: Macro Question
Post by cbb1962 »
Thank you, Marty.
I have nothing specific in mind, I'm just trying to understand the syntax on the tool setting macros. Do you know if there a macro creation tool in the works? Since Acorn is going after the DIY/Hobbyist market this could be useful.
I've looked at the Tech Bulletin #300 titled: "Creating a Custom Macro (All)" but once you open it the actual title is: "How to Setup Auxiliary Key Functionality using Canned and Custom M-codes" Nothing to help me learn how to program Macros.
In the meantime could someone that is familiar with creating Macros OR Centroid Tech Support make a video about the syntax, logic, and testing of macros? Or at least a Tech Bulletin that really does teach how to create custom macros?
Thanks.
cbb1962
Re: Macro Question
Post by cbb1962 »
I am wanting to display additional information about the tool to be changed during a tool change macro.
M225 #106 "#)Please change tool to tool #%.0f\nPress Cycle Start to continue" #4120
This will display only the tool number.
I'm using Fusion360 to create g-code. This is how the post processor displays tool information in the G-Code:
:T7  D=0.25 CR=0. - ZMIN=0. - flat end mill
I would like to display this additional information in the dialog box. Is this possible to pull this information from a g-code program? or can this functionality be added to the Router version?
I would like to display something like this:
"Please change tool to T7 D=0.25 CR=0. - ZMIN=0. - flat end mill"
Press Cycle Start to continue.
Re: Macro Question
There is no way to extract text from a comment line in the CNC file.
You could potentially change your Fusion 360 postprocessor so that it stores that piece of text in a string variable instead. Then you could refer to that string variable in the M225 prompt string.
E.g.
#300 = "T7  D=0.25 CR=0. - ZMIN=0. - flat end mill"
M225 #106 "#)Please change tool to tool #%s\nPress Cycle Start to continue" #300
or, if you want the descriptions for multiple tools to all appear at the top of the program, and provided you do not use any tool above T99:
#307 = "T7  D=0.25 CR=0. - ZMIN=0. - flat end mill"
M225 #106 "#)Please change tool to tool #%s\nPress Cycle Start to continue" #[300+#4120]
cbb1962
Re: Macro Question
Post by cbb1962 »
Your idea is intriguing, I like it!
I found the section in the Post that creates the comment, but I don't have a clue on how to do as you suggested. Are there any post guru's that could help me?
    var tools = getToolTable();
    if (tools.getNumberOfTools() > 0) {
      for (var i = 0; i < tools.getNumberOfTools(); ++i) {
        var tool = tools.getTool(i);
        var comment = "T" + toolFormat.format(tool.number) + "  " +
          "D=" + xyzFormat.format(tool.diameter) + " " +
          localize("CR") + "=" + xyzFormat.format(tool.cornerRadius);
        if ((tool.taperAngle > 0) && (tool.taperAngle < Math.PI)) {
          comment += " " + localize("TAPER") + "=" + taperFormat.format(tool.taperAngle) + localize("deg");
        if (zRanges[tool.number]) {
          comment += " - " + localize("ZMIN") + "=" + xyzFormat.format(zRanges[tool.number].getMinimum());
        comment += " - " + getToolTypeName(tool.type);
        writeComment(comment);
swissi
Re: Macro Question
Post by swissi »
It's been a while since this questions was asked but if you are still looking for a solution, this here will work:
Search in your Post Processor file for the "function onSection()" (around line 400) and in that function, look for the line "writeBlock("T" + toolFormat.format(tool.number), mFormat.format(6));"
Right above that line, insert the following code:
    var toolinfo = "#300 = "
    toolinfo += "\"T" + toolFormat.format(tool.number) + "  " +
      toolinfo += " " + localize("TAPER") + "=" + taperFormat.format(tool.taperAngle) + localize("deg");
    toolinfo += " - " + getToolTypeName(tool.type) + "\"";
    writeln(toolinfo);
This will add the Tool Info from Fusion360 in front of each M6 Tool-Change command. The G-Code file will look like this:
N10 G90 G94 G17
N15 G21
N20 G28 G91 Z0.
N25 G90
:Face1
#300 = "T1 D=50. CR=0. - face mill"
N30 T1 M6
Add the following command into your mfunc6.mac file:
M225 #106 "#)Insert Tool #%.0f\n%s\nD:%.3f    H:%.3f\n\nPress Cycle Start to continue" #4120 #300 #[11000 + #4120] #[10000 + #4120]
This will add the tool info from Fusion360 onto the first line and the 2nd line does have the tool diameter and Tool Height Offset from the CNC12 Tool library so you can compare if the info matches.
The prompt in CNC12 looks like this:
Hope this helps.
BTW if anybody knows how to access the tool description from the CNC12 Tool Library, please let me know.
-swissi
Re: Macro Question
swissi wrote: Thu Oct 18, 2018 4:41 pm
-swissi
fyi...I submitted this as a feature request to be added to future release of cnc12.
swissi
Re: Macro Question
Post by swissi »
Thanks Keith for the info regarding the new feature request to get access to the CNC12 Tool Description.
I made some improvements to the Post Processor code I posted above.
With this code, the "#300 = " line will also get a N-sequence-number when the Property "Use sequence numbers" is set to "Yes" and the whole line will be suppressed when the Property "Write tool list" is set to "No".
Here's the improved code:
if (properties.writeTools) {
       writeBlock(toolinfo);
-swissi
Re: Macro Question
very nice! thanks for posting. k
