New Centroid Acorn Control 3D Printed Case!
MarysMakeShop
Post by MarysMakeShop »
New downloadable case for Centroid Acorn. Link to download the case: https://www.thingiverse.com/thing:2872967
Miguel G. and I collaborated to make a 3D printed case for my version 3(Acorn 171025) Centroid Acorn. This case is compatible with Acorn 171025 and later. It's made in fusion 360. I've uploaded to my thingiverse the .f3d, .step and .stl file so you can change and adapt it to fit your needs!
https://youtu.be/WaK6ZS0Xnnw
Threedj16
CNC Control System Serial Number: C8FD19F23AFF-0213180659
Re: New Centroid Acorn Control 3D Printed Case!
Post by Threedj16 »
Nicely done!
ScotY
Post by ScotY »
Yes, very nice! Too bad it will be virtually impossible to produce on your typical fdm printer.
PLData
CNC Control System Serial Number: many boards
Post by PLData »
Hi,
Don't pack the Acorn board in a too close case without proper cooling,
It will burn off !!
\PLData
galyion
Post by galyion »
i printed one on my fdm printer. turned out pretty decent. i can post pics and info if anyone would like
Jeremy
Pittsburgh, PA
ScotY
Post by ScotY »
galyion wrote: Tue May 08, 2018 11:38 pm i printed one on my fdm printer. turned out pretty decent. i can post pics and info if anyone would like
Well, your printer is better than mine. :lol: No discredit to Mary, but I wouldn't even attempt to print that...I am no expert but already know it will take a long time with tons of support necessary, and look really bad in the end.
Grifftek
CNC Control System Serial Number: 0503160222
Post by Grifftek »
I printed one of these cases in FDM and noticed a few little issues that I corrected for my build. I emailed Mary and I will upload my STL files on Thingiverse if anyone else wants to use them.
In FDM:
In SLS and painted:
More photos can be found here:
Thanks for all the hard work putting the 3d models together!
Bill
Sword
Post by Sword »
Bill,
Did you ever upload your files to Thingiverse? I printed the base, but found that the standoffs are to low. How did the holes for releasing the catches work out?
I'd like to make it with a flat top so that I could do a color change for the logo.
Scott
Scott
cncman172
CNC Control System Serial Number: 985DAD429EE9-0926170118
Post by cncman172 »
Mary,
Ignore all the negative comments, I think you did a great job. As long as there is a little clearance in that case it should work perfect. You can touch y our Acorn after being on days and it is barely warm.
You made me put a 3D printer on the top of my toy list. ha ha
Russ
