cnc12 lathe or mil not starting
_______________________________________________________
LOGIN below to POST your questions and comments on AjaxCNC products.
Serge10667
System Serial Number: none
Post by Serge10667 » Tue Jan 23, 2018 8:27 pm
I installed new CNC12 lathe worked fine with the test set up
I installed CNC12 mill on the same PC, not starting and CNC 12 lathe not starting also, the led communication and blue hard beet are ok.
How do I fix this problem?
Can we install both lathe and mill on the same PC
Serge10667
Re: cnc12 lathe or mil not starting
Post by Serge10667 » Wed Jan 24, 2018 1:48 am
Hi,
The problem was no communication with the Ethernet the green light was not blinking.
I powered down the 24V supply and restarted it, the cnc121 is communicating correctly with the PC with the green light blinking all the time. Both programs CNC 121 Lathe and Mill are working correctly.
Hope this will help someone else.
frijoli
System Serial Number: none yet
Post by frijoli » Wed Jan 24, 2018 2:14 pm
Thanks for sharing the solution!
Clay
Clay
near Winston-Salem, NC
unofficial fb group https://www.facebook.com/groups/897054597120437/
Who is online
Users browsing this forum: mael and 1 guest
