dc servos Axis jumping when moving <<Resolved, tune motors.>>
_______________________________________________________
LOGIN below to POST your questions and comments on AjaxCNC products.
toolmaker101
System Serial Number: 102978, 8121, REV233
Post by toolmaker101 » Tue Jan 02, 2018 6:21 pm
I just had new control installed on my mill. Right after the install the z would only freeze and jump in rapid moves now when I move the Z axis it freezes and jumps so i hit the E stop. It will only move in slow with the feed turned down all the way. I can gradually turn the feed up wile it is moving to get it to go faster but if I stop and try to move at the faster rate it will freeze up add go to shacking the hole machine.
Thank you in advance for your help,
frijoli
System Serial Number: none yet
Re: Axis jumping when moving
Post by frijoli » Tue Jan 02, 2018 8:44 pm
What control board do you have., What motors and drives?
Clay
Clay
near Winston-Salem, NC
unofficial fb group https://www.facebook.com/groups/897054597120437/
toolmaker101
Post by toolmaker101 » Wed Jan 03, 2018 12:25 pm
cnc11 mpu11 Qudra drive, X & Z are SEM motors Y is an new Centroid motor installed last year.
toolmaker101
Post by toolmaker101 » Wed Jan 03, 2018 1:12 pm
Hear is a currant report. also the control # is 102978
Thank you.
report_1013171367_2018-01-03_11-06-32.zip
(1.15 MiB) Downloaded 11 times
Post by cncsnw » Wed Jan 03, 2018 4:27 pm
Do you think the issue might be related to the many "407 ... limit tripped" conditions reported in your error message log? Or to the couple "9030 SPINDLE FAULT" messages?
Use the Alt-i PLC Diagnostic display to see whether all six limit inputs (INP1 - INP6) are green, and stay green except when the limit switches are actually tripped. Also check whether INP14 is green, and stays green except when your spindle drive is actually in a fault condition.
Do the X and Y axes move smoothly and under control?
My guess is that you have a faulty (or maybe just loose) position encoder on the Z axis motor.
toolmaker101
Post by toolmaker101 » Wed Jan 03, 2018 5:04 pm
Thank you
The many 407 is me trying to get the machine limits set using the Test in setup config. When I turn on the mill I get the warning the machine is not setup message contact your dealer! I am using the "Tech Bulletins 289 Software Travel Limits" to try set them up. But scene the z messes up I cant complete the test.This will be an issue fore another day.
The 9030 has been going on for a wile it goes away with an Estop I Hoped to have that looked into when I had the new control put on but that did not happen.This will be an issue fore another day.
The Z axis issue came up right after the new control was put on This is an issue that keeps me from using the mill.
I will swap the encoder with a new one. and let you know if it helps.
Thank you
Post by cncsnw » Wed Jan 03, 2018 5:11 pm
Before buying a new encoder, you might try to expand upon "freeze up", "jump", and "shacking the hole machine" for us.
Does the encoder position for the Z axis (as shown under "Abs Pos" on the PID Configuration screen) count consistently when you turn the Z axis motor by hand?
Does the '*' next to the Z in the left-most column of that display, indicating the location of the encoder index pulse, always appear at the same motor shaft position, even after a stall episode?
What kind of machine is this?
Does the Z servo motor have a holding brake? If so, what voltage does the holding brake use for release, and where does that voltage come from?
toolmaker101
Post by toolmaker101 » Wed Jan 03, 2018 6:21 pm
I have 1 used old style encoder like in the pitcher and 2 brand new, new style ones on the shelf.
The machine is a Revolution 3 axis bed mill.
I will try to get you the info on the encoder asap.
toolmaker101
Post by toolmaker101 » Wed Jan 03, 2018 6:23 pm
That is my old y axis motor on the table I stooled the encoder off of it just a wile ago.
toolmaker101
Post by toolmaker101 » Wed Jan 03, 2018 7:22 pm
Explaining freezing jumping and shaking. The attached pitcher is right after I pushed the Z down arrow the head goes down a small amount then it stops going down "freezing up" and the head starts going up and down very little I call this jumping. I gets so sever it shakes the hole mill. It will not stop until I hit the estop.
Does the encoder position for the Z axis (as shown under "Abs Pos" on the PID Configuration screen) count consistently when you turn the Z axis motor by hand? YES even after it freezes and jumps.
Does the Z servo motor have a holding brake? If so, what voltage does the holding brake use for release, and where does that voltage come from? The wiring diagram shows it as a option @ 24 VDC
I have the cap off of the Z motor and it has 2 extra wires that my old y motor dose not have. must be that brake???I will open the electrical cabinet and see were they go!
I will have to get back to you as I am typing this up on the mill console.
Who is online
Users browsing this forum: lvanduyn and 2 guests
