Reason not to make lathe reference tool "T00"?
DICKEYBIRD
System Serial Number: n/a yet
Post by DICKEYBIRD » Thu Dec 07, 2017 3:35 pm
Here's what the manual says: "Tool Loc (Tool Number): This is the Tool Number (01-99) that is associated with the Tool Offset."
The tool tables for my ORAC in both Mach3 and DolphinCAM were both set up with the reference tool to be T00. It is ref'd at the X-axis centerline which is where my very accurate x-axis homing location is. I checked & it looks like I can add 00 to the Tool Loc list and it appears to Save OK. I have 25 tools set up now so will never need 100 which I think is the limiting factor. I know this probably seems weird but it is the way it was set up originally & what I'm comfortable with. Any reason not to do this with CNC12?
Milton in Collierville, TN
Centroid_Tech
Re: Reason not to make lathe reference tool "T00"?
Post by Centroid_Tech » Fri Dec 08, 2017 10:08 am
That should work.
Dave_C
System Serial Number: none
Post by Dave_C » Fri Dec 08, 2017 10:13 am
Just sharing my experience with Tool T00..
From what I've experienced with Mach3, running it on my CNC lathe, Tool 00 is not to be used as an actual tool. This makes it impossible to take an actual cut with the master tool. I suppose it can be used as a reference but I don't know how to make use of it properly.
Setting up lathe tools are quite a bit different than setting up mill tools in that they take different cut depths in different metals and when using different depths of cut and feed rates. Then add in "spring" and you see why us old manual machinist take a three cut approach to the final pass. Cut, measure, cut measure and then adjust the cut for the final diameter. You can't really do that in CNC nor would you want to but you do need to know how to make that tool hit the desired diameter.
My X axis references very well and I use Tool 01 as my master tool and then set all tool offsets from that tool, using actual test cuts to set tool offsets. This has produced very accurate results so far.
So as to making T00 your reference tool, if theoretical tool setups are close enough, then I would say it will work. IF you need actual test cuts, then you may want to use T01 as your master tool.
My two cents worth,
Dave C.
Grizzly G0678 CNC conversion with Acorn in progress!
DICKEYBIRD
Post by DICKEYBIRD » Fri Dec 08, 2017 10:52 am
Thanks guys. :)
Many of my tools are set up & tuned for a particular insert, material type, dia. & sfm so they can be relied on to give consistent results. When an untested combination came up while using Mach, I simply typed in a negative tool wear value, made the part, measured & adjusted to suit. Hopefully the Centroid software will allow the same procedure. I'm old & set in my ways. ;)
Post by martyscncgarage » Fri Dec 08, 2017 3:00 pm
Thanks guys. :)
Milton, RTFM, dig in and TELL US what works for you. :D
Looks like Centroid gave you the nod.
Keith is making engine blocks and cylinder heads at PRI this weekend. So he'll be back into the mix next week after he plays catch up.
Keith did a good job I think with the lathe operator's manual where setting lathe tools is concerned. I had ZERO experience with a CNC lathe until I was doing testing on it. I followed the manual and was able to cut a part or two without ugly things happening! :shock:
DICKEYBIRD
Post by DICKEYBIRD » Fri Dec 08, 2017 5:12 pm
I'm trying Marty! My buddy down the street keeps bringing me emergency stuff from his company to machine on the weekend & it's been busy at my day job. That leaves me about 11.2 nano-seconds on weeknights after I get home to play with Acorn stuff before I get sleepy.
Hopefully It won't be too much longer 'til the ORAC's making some decent parts to show n' tell. :roll:
Who is online
Users browsing this forum: Centroid_Tech, lilb93 and 2 guests
