Fusion 360 mill/turn and turn post processor non-existent! (use Intercon)
frijoli
System Serial Number: none yet
Post by frijoli » Sat Nov 25, 2017 8:56 pm
I've been programming my Centroid mill with it.
I went to test a post for Acorn lathe and there is NO post processor for turning or Mill turning! Not just for Acorn but for Centroid as a whole.
:cry: :evil:
While I can get away with this in the short term, long term it's going to be an issue. I will have live tooling on my lathe and it gets tedious programming it. Especially since I haven't programmed a lathe in 18 years.
If you guys are using Fusion, you need to put in a request there as well as with Centroid.
Clay
Outside Winston-Salem, NC
Re: Fusion 360 mill/turn and turn post processor non-existent!
Post by martyscncgarage » Sat Nov 25, 2017 10:59 pm
Clay, my buddy is testing my Dyna DM2400, and learning the Centroid software. He is also cutting his teeth on Fusion 360. He said there is a Centroid Post processor (1)?
frijoli
Post by frijoli » Sat Nov 25, 2017 11:55 pm
There is one for milling. It works very well.
I haven't seen any lathe posts, and I can verify that the mill post processor fails when trying to output a turning sequence! lol
I am going to see if I can modify a Haas mill turn.
Not really into Javascript....
Clay
Edit: it looks like the HAAS mill/turn may be easy enough to replicate.
Post by martyscncgarage » Sat Nov 25, 2017 11:58 pm
Clay
Ah, I see...
Maybe its easier to see which Posts work with Centroid Lathe.
frijoli
Post by frijoli » Sun Nov 26, 2017 11:09 am
My task for today. Convert a turning post processor for Centroid, and hopefully mill turn and test in the control. (since my lathe is still in pieces)
Also, drink some scotch. :)
DICKEYBIRD
System Serial Number: n/a yet
Post by DICKEYBIRD » Sun Nov 26, 2017 3:45 pm
I have the same issue to deal with down the road but with Dolphin Partmaster Lathe. The only reference I found says Fanuc 0T. I hope it's close enough to be able to make it work!
Milton in Collierville, TN
frijoli
Post by frijoli » Sun Nov 26, 2017 4:37 pm
I am gaining ground! I have a post working about half way. It's showing in the graph, and it runs some of the code.
DICKEYBIRD
Post by DICKEYBIRD » Sun Nov 26, 2017 4:48 pm
Cool, what did you start with...Fanuc?
frijoli
Post by frijoli » Sun Nov 26, 2017 5:21 pm
Started with Fanuc and Mach3.
Posted tested, adjusted, posted tested, adjusted, posted tested. Scratched my head... Now on to the scotch.
midy
Post by midy » Sun Nov 26, 2017 6:51 pm
Just to be 100% clear, are you boys saying there is no PP for fusion 360 and acorn lathe?
Who is online
Users browsing this forum: No registered users and 1 guest
