New Build LMS 3990 Hi Torque Mini Mill
cdiseker
CNC Control System Serial Number: 20D77886DD3D-0112247834
Re: New Build LMS 3990 Hi Torque Mini Mill
Post by cdiseker »
tblough wrote: Mon Jun 24, 2024 4:38 pm Adjusting the turns ratio cannot correct for poor mechanicals. Loose belts, poorly meshing gears/racks, slipping couplings, sloppy gibs, loose bearings, loose ways or guide rails, or sloppy gear reducers will all affect repeatability.
This machine does not have many hours on it. I was wondering if the ball nuts needed adjusting. I'll re-do my gibs now and double check the numbers.
If the turns ratio was set correctly when new, and cannot be adjusted now, then it is definitely something mechanical.
