New Build LMS 3990 Hi Torque Mini Mill
cdiseker
CNC Control System Serial Number: 20D77886DD3D-0112247834
Re: New Build LMS 3990 Hi Torque Mini Mill
Post by cdiseker »
tblough wrote: Wed May 01, 2024 5:09 pm If you are already doing manual tool changes, post each tool path as a separate file. Then, just do the tool change before running the file.
I actually found a way to get this added to the program. Seems Fusion added the tool. I followed instructions and in the simulation there is a stop at the beginning of each tool number. Then I'd changed tools and hit Cycle Start twice to resume.
Setup
Manual NC
Tool Change
Only challenge now ...getting the code to Centroid/Mill to cut the part.
cdiseker
Re: New Build LMS 3990 Touch & wheel jogging
Post by cdiseker »
Jog question: I have a MPG. Are there settings I can update to change the increment of advance on the MPG buttons and wheel?
cdiseker
Tool Library conflicts?
Post by cdiseker »
If I'm using Fusion for a Tool Library AND to process the G-code should the tool library in Centroid be populated? Wouldn't this create a conflict?
Axis configuration in the Wizard, x1 Linear Jog Increment.
Re: Tool Library conflicts?
cdiseker wrote: Thu May 02, 2024 4:22 pm If I'm using Fusion for a Tool Library AND to process the G-code should the tool library in Centroid be populated? Wouldn't this create a conflict?
You have to setup tools in CNC 12 like in fusion by hand.
With the next upcoming ProbeApp from swissi you can import fusion tool libs in CNC12.
cdiseker
Post by cdiseker »
suntravel wrote: Thu May 02, 2024 4:24 pm Axis configuration in the Wizard, x1 Linear Jog Increment.
Not what I mean exactly. When I Reset Home and get 0,0,0 I turn my handwheel on the wireless MPG one click +/- X or Y and the DRO displays the expected amount. When I press the buttons on the MPG I get a number different than the 0.100 increment and even a different number when I click on the VCP. It's acting like some parameters are different somewhere.
I will remember the Wizard idea you shared, thanks.
MPG and VCP works the same way, but if you have not selected incr. move, the way it moves depends on the time you press the button ..
cdiseker
Post by cdiseker »
suntravel wrote: Thu May 02, 2024 4:27 pm
So, My Tool Lib in Fusion needs to match my Tool Lib in CNC12?
cdiseker
Post by cdiseker »
Suntravel,
I SEE IT NOW!!! The reference earlier to the Wizard settings is for BOTH the MPG & VCP. I also see that the INCR 1x is not 0.001" but 0.0001" and all else is a factor of that base. HOLY CRAP the light bulb just went off. I've been wondering "WTH is wrong" for over a week now. Man, this really helps. THANK YOU.
cdiseker wrote: Thu May 02, 2024 4:53 pm
It is better this way because RTG is using the tool Diameter from the Lib for display, and if you use swissi PP with his M6 macro, data from CNC12 lib is compared to fusion and the values from CNC12 are displayed for a manual tool change.
If you use diameter compensation in CNC12, it MUST match to fusion.
