I suspect that your problems are caused by the 50" per revolution roughing feedrate. You will also run into problems with the 10" per rev finish feedrate. You didn't attach a report but I suspect movement initally stopped because your drive faulted. When reset the control, you didn't re-home the machine which exacerbated the crash.
On an open-loop machine, whenever you have a drive fault or any condition that causes lost steps, you HAVE to re-home the machine. If you do not have index/hard-stop/accurate switch homing, you will also need to re-calibrate your tools.
New Build: Another Techno Lathe
Re: New Build: Another Techno Lathe
- CNC Control System Serial Number: Acorn-905
I don't know, very mysterious indeed. Probably related to the absurd feed rate mentioned below.
50" per revolution? Oops, my brain was in IPM mode. This is what happens when a router guy starts messing with a lathe. I'll do some homework.tblough wrote: ↑Sat Sep 23, 2023 5:23 pm I suspect that your problems are caused by the 50" per revolution roughing feedrate. You will also run into problems with the 10" per rev finish feedrate. You didn't attach a report but I suspect movement initally stopped because your drive faulted. When reset the control, you didn't re-home the machine which exacerbated the crash.
My build: Making a CNC P-to-P boring machine less, uh, boring: https://www.cnczone.com/forums/diy-cnc- ... -axis.html
