francoCNC
Posts: 42 Joined: Tue Sep 19, 2017 11:26 pm
CNC Control System Serial Number: B0D5CC39D321-0822170083
Post
by francoCNC » Wed Nov 22, 2017 7:16 pm
martyscncgarage wrote: ↑ Tue Oct 31, 2017 3:23 pm
Yep, I pulled the cover off to take a peek at the inside of the encoder. I also got a message from the Ebay seller.
See what surprising info I got out of our discussion...
https://youtu.be/OI-4-1K2q_A
Hi Marty. Question: I'm told that when it comes to spindle encoders, it is possible to have too many pulses per revolution and that at a given RPM the encoders stop reading correctly. What light can you shed on that topic?
Also - do you know how setup the forum profile so you get email notifications?
-Franco
ScotY
Posts: 654 Joined: Sat Sep 23, 2017 7:57 pm
Post
by ScotY » Wed Nov 22, 2017 8:32 pm
Hey Brad,
If you go to the user control panel (click on your username top right), then board preferences, then edit posting defaults...notify me on replies. I'm pretty sure that's what I did. Maybe also look at edit notification options.
Posts: 9958 Joined: Tue Mar 28, 2017 12:01 pm
Post
by martyscncgarage » Thu Nov 23, 2017 6:32 pm
Most encoders have an RPM rating. You'd need to check their cut sheet. The Chinese Omron is a crap shoot. Centroid recommends a 2000 line encoder. (8000 in quadrature)
midy
Posts: 296 Joined: Wed Oct 11, 2017 12:20 pm
Post
by midy » Thu Nov 23, 2017 6:58 pm
My seller admitted the omron encoder is fake and refunded me!
Post
by martyscncgarage » Thu Nov 23, 2017 7:00 pm
He offered to do the same. But I decline. I pretty much knew what I was getting when I bought it.
It did "work"
midy
Post
by midy » Sat Nov 25, 2017 1:21 pm
I know you tested your fake Marty but is it actually in use as we speak? (type!)
Post
by martyscncgarage » Sat Nov 25, 2017 1:25 pm
midy wrote: ↑ Sat Nov 25, 2017 1:21 pm
Right on. I hoped someone would really put it through the ringer. Keep us posted. Lathe?
762x51
Posts: 135 Joined: Wed Aug 02, 2017 8:40 pm
CNC Control System Serial Number: B0D5CC56DD75-0605170063 , 985DAD4295CF-0928170127 , 38D2694E4703-1222170401
Post
by 762x51 » Sat Nov 25, 2017 1:30 pm
martyscncgarage wrote: ↑ Sat Nov 25, 2017 1:25 pm
I plan on using one on my DM-3000 Lathe conversion that I hope to start early next year.
Orin
Post
by martyscncgarage » Sat Nov 25, 2017 1:54 pm
762x51 wrote: ↑ Sat Nov 25, 2017 1:30 pm
Orin
Looking forward to your build Orin. Might serve as inspriation to get me going and finishing up the one I have. Post pics!
762x51
Post
by 762x51 » Sat Nov 25, 2017 2:28 pm
Will do Marty.
Having to make new ClearPath servo mounts for both the X & Z axis and this X Axis layout will only have a 4:1 (ClearPath : Lead Screw) ratio.
I'd like to have a 10:1 ratio but you'd have to modify the existing lead screw mount and I don't want to do that. I do think the 4:1 ratio will work fine with the ClearPath servos I already have.
In this design the ClearPath timing belt pulley is 18 tooth and the Lead Screw is 72 tooth.
