Eithernet cable
dhspring
Eithernet cable
Post by dhspring »
What are the cat ends that plug into the all in one board and the other parts for the shielded eithernet cable?
Centroid_Liviu
Re: Eithernet cable
Post by Centroid_Liviu »
It is a RJ-45 Shielded CAT5E cable and jack. Are you trying to make your own? We sell Ethernet Cable in various lenghts, you can also source it all over the internet, as long as its Shielded CAT5E or above it should work.
If you are looking to build your own I have attached a Technical Bulletin with the full details.
251.pdf
TB251 Ethernet Cable for Centroid Systems
(68.56 KiB) Downloaded 93 times
