Acorn ERRORS during first move <resolved>
Re: Acorn ERRORS during first move
it ignores , take a look at the I/O table when you select Bench test radio button..
ScotY
Post by ScotY »
I don’t know...100ipm with a >50:1 reduction sounds like your motor rpm is gonna be way too high.
762x51
CNC Control System Serial Number: B0D5CC56DD75-0605170063 , 985DAD4295CF-0928170127 , 38D2694E4703-1222170401
Post by 762x51 »
ScotY wrote: Tue Jan 09, 2018 6:42 pm I don’t know...100ipm with a >50:1 reduction sounds like your motor rpm is gonna be way too high.
It does -
What's the ball/lead/acme screw turns/inch or mm/rev if metric?
BrandSacped
Post by BrandSacped »
Its a belt drive for an axis that is basically a conveyor system that takes parts through a sand blasting cabinet. I tried to talk to the owner about converting it to a PLC but when I saw the conversational programming capabilities of the Centroid system we went that rout.
BrandSacped
It's all working now. I did put it into bench test mode like suggested, it still moved slowly on it's own as soon as motion was commanded. In ClearPath MSP I found the homing radio button checked, so I unchecked it. Problem solved! It's always the stupid little things isn't it? I still don't know what all the error codes I was getting were.
I reset everything to factory defaults in both acorn and ClearPath MSP and went through step by step testing between each one to make sure each implementation worked.
So thanks to all who commented, my client is happy and I'm happy. :D
