Poor mans DNC without network
Since I have my CNC PCs set up fast and unsave I avoid to connect them to the network, but plugging the thumb drive form CAM to CNC and copy files sucks also :lol:
My solution is to use an USB switch and USB Flash Copy.
The thumb drive is plugged in the switch and form the CAM PC I let the PP write to the drive, than I only need to push the buttom on the switch and the file is automatic copied to the \cncm\ncfiles Folder on the CNC PC
In this example I decided to make two same parts because I have a second vise on the mill. Saves tool changing, because fusion is told to use each tool in G54 and G55 before change
Re: Poor mans DNC without network
cool. love it!
slodat
Post by slodat »
I have a G_Code folder for each of my CNC machines in Dropbox. When I post the code on the CAM computer the posts are setup to save to that folder. Then I walk to the machine and it’s there, local and ready to run.
slodat wrote: Fri Nov 04, 2022 3:34 pm I have a G_Code folder for each of my CNC machines in Dropbox. When I post the code on the CAM computer the posts are setup to save to that folder. Then I walk to the machine and it’s there, local and ready to run.
Does that mean the CNC machines are connected to the internet?
slodat
Post by slodat »
Yes. And I have zero issues. They are on a vlan that greatly limits their internet access.
gerald martin
Post by gerald martin »
Same here. Dropbox works great. I don't know if I shared this before or not, but with Dropbox I also use Boxifier. Then you can sync a specific folder such as "ncfiles"
https://www.boxifier.com/
I use the free version. I save directly to the ncfiles folder from Aspire, then go to my machine, hit load and there the gcode file is!
Gerald
gerald martin wrote: Wed Nov 09, 2022 8:13 pm
Gerald
cool! thanks for posting
