Acorn CNC12 Mill, Router, and Lathe v4.64 has been released! < v4.80 has superseded v4.64>
Re: Acorn CNC12 Mill, Router, and Lathe v4.64 has been released!
Acorn v4.80 has been released. (8-12-22)
Crosshatch wrote: Fri Aug 12, 2022 3:37 pm No, never had internet on this computer. I'm pretty far from my router.
Everytime I open CNC12 that window pops and no VCP. Can only jog from Pendant. Fixed direction of Z axis, but at the moment, nothing else works without my VCP.
You can try to download only Net Framework 4.8 and install with USB stick:
https://support.microsoft.com/de-de/top ... 3c3e7495e0
Crosshatch
CNC Control System Serial Number: 38D269931CF1-0307180710
Re: Acorn CNC12 Mill, Router, and Lathe v4.64 has been released! < v4.80 has superseded v4.64>
Post by Crosshatch »
Okay, I will make a report and post it.
I tried to download the Net from the USB, but it said my windows did not support it.
Crosshatch
Again, I tried to download the NET Framework from USB but said my Windows Doesn't support.
My Report from v4.80 and previous version attached.
report_38D269931CF1-0307180710_2022-08-12_02-35-45.zip
(243.98 KiB) Downloaded 17 times
report_38D269931CF1-0307180710_2022-08-12_21-18-40.zip
(747.33 KiB) Downloaded 16 times
To start with you don't have the proper display resolution set to display the software correctly. It needs to be 1920x1080 to display properly. You have it set to 1680x1050 so it's gonna look weird. Your old report said you were running Windows NT and version 4.10 but at least you updated those. Fix your resolution and see if that helps with the VCP.
Have you read the PC requirements for running Centroid software? Have a look here:
https://www.centroidcnc.com/cnc_pc_perf ... ments.html
And please start your own build thread/topic so we can follow along and you can keep all your posts and questions in one place so as not to hijack this topic.
Crosshatch
All I got it. I downloaded the correct NET Framework and installed. VCP popped up and boy what a difference with resolution. Spindle is not perfect but way better. I'll make my own thread, thanks for the help all.
cnckeith wrote: Fri Aug 12, 2022 3:55 pm Acorn v4.80 has been released. (8-12-22)
And now it runs on my machines, no problems updating.
Thank you very much :)
