Millport with a Knee
lilb93
System Serial Number: 0216041209
Post by lilb93 » Mon Dec 04, 2017 12:32 pm
Was going to use the MAE HY 200-4270-710 A 8 steppers and just replace the DC drive units with CWD 2008 drive boards.
Now I an just going to move to Servos. The MAE HY 200-4270-710 A 8 are rated at 1525 OZ. Would I have to replace them with the same numbers of oz's ?
Are servos stronger than steppers ?
Even the Z axis has the same rating stepper motor on as the X and Y.
The choice is either clearpath which is DC or DMM which is AC.
Does one work better than the other? Thanks
Barnesville, PA.
Centroid_Liviu
System Serial Number: none
Re: Millport with a Knee
Post by Centroid_Liviu » Mon Dec 04, 2017 4:40 pm
On that size machine typically all axis motors will be the same size. The thing to remember with stepper motors is that they only can do their full rated torque when they are holding position. A servomotor will have a much better torque curve. For that size machine I would recommend something in the 29in-lb on the DC side or about 500w-750w on the AC side.
lilb93
Post by lilb93 » Mon Dec 04, 2017 11:38 pm
The figures, would that be on the peak or constant. What RPM should they be able to run at. Rated and Max Rpm. Thanks
Barnesville, PA.
lilb93
Post by lilb93 » Tue Dec 05, 2017 2:48 pm
Well I talked to DMM and they have the exact replacement for the nema 42 steppers I have now with there 1.5KW drives.
There waiting on the motors from China. Should take 4 weeks. They don't show nema 42 mounts with 5/8 shafts on there website. But they do have them. Actually they only have one in stock. So it is now hurry up and wait. Ordered 3 1.5Kw servos
and 3 DYN4 drives, and all the cables in 5M lengths to play it safe.
That should be enough power for it.
Barnesville, PA.
Post by martyscncgarage » Fri Dec 08, 2017 8:13 am
That's nice to know. DMM recently added a couple more standard NEMA 23 and 34 AC servos to their line. Its good to know they are adding NEMA 42 as well.
Keep us posted.
"Jack of all trades, master of none!"
Who is online
Users browsing this forum: No registered users and 1 guest
