Offline Intercon
Centroid_Liviu
System Serial Number: none
Re: Offline Intercon
Post by Centroid_Liviu » Thu Nov 30, 2017 2:30 pm
[/quote]Will it do both lathe & mill Intercon and what about using it on a couple different PC's as long as the dongle's plugged in on the desired PC.
[/quote]
You can do both Mill and Lathe. You can install on as many PCs as you want. You can switch the USB dongle between them, otherwise you are limited to 20 lines of Intercon.
DICKEYBIRD
System Serial Number: n/a yet
Post by DICKEYBIRD » Thu Nov 30, 2017 2:46 pm
Awesome, thanks! Well worth the price as there's no telling where & on who's PC I get the time to work on code for a project.
Milton in Collierville, TN
DICKEYBIRD
Post by DICKEYBIRD » Fri Dec 01, 2017 2:40 pm
So I got it today at work, that's what the $15 was for. Very quick, thanks Centroid! :)
DICKEYBIRD
Post by DICKEYBIRD » Fri Dec 01, 2017 2:50 pm
Hmm, looks like I need a Sentinel driver. Does anyone have a link to the correct driver or to installation instructions? The box had the dongle and nothing else.
frijoli
System Serial Number: none yet
Post by frijoli » Fri Dec 01, 2017 4:18 pm
Have you tested just plugging in the dongle and try Intercon? Mine said I needed driver but I didn't install it, and intercon worked as intended.
Outside Winston-Salem, NC
DICKEYBIRD
Post by DICKEYBIRD » Fri Dec 01, 2017 4:38 pm
I plugged it into my work PC which doesn't have CNC12 loaded and nothing happened. Is it possible to load Intercon without an Acorn hooked up? I know it's a stretch but imagine you're dealing with a dunce when you answer. :lol:
frijoli
Post by frijoli » Fri Dec 01, 2017 4:43 pm
The usb thing is just a KEY. I don't recall how I loaded intercon, but I'm pretty sure it was a link and D/L.
Acorn does NOT have to be attached. hence the "offline"
DICKEYBIRD
Post by DICKEYBIRD » Fri Dec 01, 2017 5:10 pm
The key concept I understand, it's how to load Intercon separately that I'm scratchin' my head over. I couldn't find a link.
diycncscott
Post by diycncscott » Fri Dec 01, 2017 6:34 pm
Download 3.16 from here: http://www.centroidcnc.com/downloads/so ... v316-D.zip
And install Mill Demo and/or Lathe Demo. The demo will change to full blown offline with dongle connected.
You'll find the Sentinel drivers in there as well.
Do NOT install the 3.16 Mill or Lathe control software. It is not compatible with Acorn hardware.
DICKEYBIRD
Post by DICKEYBIRD » Fri Dec 01, 2017 7:20 pm
Thank you Scott; it worked great!
Who is online
Users browsing this forum: No registered users and 4 guests
