My Bridgeport Series 1 CNC Conversion Using Centroid Acorn
DICKEYBIRD
Re: My Bridgeport Series 1 CNC Conversion Using Centroid Acorn
Post by DICKEYBIRD »
Reedfirst wrote: Thu Nov 16, 2017 6:07 pm Come on by! I'll pour you a cup!
Heck I'll even bring the cream & a couple shots of Jameson's & we'll do it up Irish style. :D
Milton in Collierville, TN
Reedfirst
Post by Reedfirst »
DICKEYBIRD wrote: Thu Nov 16, 2017 6:52 pm
I think you might be on to something!! :lol:
Reedfirst
Post by Reedfirst »
Made a little more progress...
I wanted a nice way for my Encoder and servo power supply cables to feed through my electrical cabinet so I designed this panel in Fusion360, machined it out of .625 aluminum sheet, powder coated it, put it back in the mill and did the engraving.
I"m really happy with the way it turned out.
Reedfirst wrote: Wed Nov 29, 2017 10:26 am Made a little more progress...
Very clean, nice work!
DICKEYBIRD
Nice, gotta love Speakon connectors!
Reedfirst
Post by Reedfirst »
DICKEYBIRD wrote: Wed Nov 29, 2017 12:09 pm Nice, gotta love Speakon connectors!
Yup Speakon! I love them. This is my first time using them and definitely won't be the last. Apparently they make a whole array of connectors and sockets as I'm learning. They are really high quality.
I've been learning so many thing about cnc controls, software, programming,g-code as well as the hardware used. Some might say converting a manual machine is a losing proposition. Now that I'm 3/4's the way through I must say I'm glad I took on this project. The knowledge I've gained in doing this coversion is worth the price of admission alone.
The only thing I need now is more Time In The Seat.
(There may or may not be an acronym somewhere) 😅
frijoli
Post by frijoli »
My favorite acronym!
Clay
near Winston-Salem, NC
super nice, will you share the G code program?
Reedfirst
Post by Reedfirst »
cnckeith wrote: Thu Nov 30, 2017 8:36 pm super nice, will you share the G code program?
Sure!
BulkheadPanel.rar
(59.47 KiB) Downloaded 115 times
There are two g-code programms in the compressed file.
The machining and the engraving.
I do edit the Centroid Post from Fusion 360 so that after every tool change (M6) I add X-2 Y0. just a comfortable place to do the tool change manually for me.
I also edit this line at the end of the program so the Table goes to the same comfortable position at the end instead of home.
N28080 G90 X-2. Y0.
The program calls out tool 24 for the drilling operations which is a 1/8 drill in my tool library however, I just use a #34 drill bit instead at the same height offset as the 1/8 drill bit (just a sharpie mark on the drill bit)
There is also an extra tool change programmed in so I can screw the aluminum sheet to a piece of mdf I used as a spoil board/fixture after the 4 holes at each corner were drilled. I just use tape to temporally hold the aluminum to the mdf until those 4 holes are drilled
cncman172
CNC Control System Serial Number: 985DAD429EE9-0926170118
Post by cncman172 »
Readfirst,
You are doing a very nice job on your conversion. Congrats.
Russ
