Are there any good guides on cutting tappers with Acorn?
ChrisMe
Post by ChrisMe »
I'm finding programming tappers very confusing as every time I entre a new number into the CAD it greatly alters the shape of the tapper. Basically I want to cut a taper that at z -0.5 the diameter is 1 inch then I want the tool to cut a 20 degree taped until z-1.5. How do I do this? Thanks.
polaraligned
Re: Are there any good guides on cutting tappers with Acorn?
Post by polaraligned »
Cutting a taper? What CAM do you have?
ChrisMe
Post by ChrisMe »
polaraligned wrote: Wed Oct 20, 2021 8:19 am Cutting a taper? What CAM do you have?
I'm using the Centoid Lathe Free CAD.
ZZBOB
CNC Control System Serial Number: 20915A (1124081904)
Post by ZZBOB »
HI Chris...
Post a sketch or Dwg..of your part with good dimensions ...and then I can help you out....
BOB....
I assume you are using the Turning cycle (F7). You need to specify the ending X and Z. The software applies the taper working back from the end point, to adjust your start point.
Z is moving 0.5 inches, at a 20-degree angle.
0.5 * tan(20) = 0.182.
X needs to move out (+) 0.182 per side, so 0.364" increase in diameter.
Therefore your ending point is X1.364 Z-1.50.
Enter a turning cycle that goes to X1.364, Z-1.5, then ask for a -20 degree taper. A negative taper makes the starting diameter smaller.
ChrisMe
Post by ChrisMe »
cncsnw wrote: Wed Oct 20, 2021 12:17 pm I assume you are using the Turning cycle (F7). You need to specify the ending X and Z. The software applies the taper working back from the end point, to adjust your start point.
Thanks. I'll give this a go.
to turn a cylinder and than a taper I would use F6 Profile in Intercon.
Regards
antsct
CNC Control System Serial Number: 4102
Post by antsct »
Don't have the F6 Profile button on my set up, but I have the free soft ware that came with it. Do I need to purchase a soft ware upgrade from Centroid?
The profile function is part of Intercon that comes with all versions of CNC12. Once you start Intercon, press F3 Insert, and then F6 Profile.
