Hardinge TFB
Post your completed retrofits for the world to see.
Hardinge TFB
It's been a long while getting to this point, but I can start to see the light at the end of the tunnel. This is a 1982 Hardinge TFB that had been involved in an abusive relationship. I rescued it at an auction, completely disassambled, cleaned, painted, ground, scraped, and am finally re-assembling and converting to CNC.
I am just now starting on the electrical cabinet so I hope to make some chips with it before the year end.
Re: Hardinge TFB
More Photos. Paint was PPG Amercoat 2 epoxy primer and PSX700 polysilane topcoat with a lot of bodywork underneath. I picked up a car shelter on sale from Tractor Supply which made a great paint booth and kept the wife from complaining about paint fumes in the house.
Re: Hardinge TFB
Re: Hardinge TFB
And this is the current portion of the project. My goal was to fit everything within the footprint of the original machine so it could still fit through a 36" basement door.
More photos to follow....
Re: Hardinge TFB
Here's a few more I found of indicating the Z ballscrew and scraping the ballnut block to dial it in.
frijoli
Re: Hardinge TFB
Post by frijoli »
tblough wrote: Tue Nov 07, 2017 10:17 pm I picked up a car shelter on sale from Tractor Supply which made a great paint booth and kept the wife from complaining about paint fumes in the house.
Very nice work! Great idea on the "carport".
Clay
near Winston-Salem, NC
diycncscott
Re: Hardinge TFB
Post by diycncscott »
Wow. Beautiful.
Makes me want to put it in my living room just to look at. :)
Re: Hardinge TFB
Thanks guys. I'm not planning on making a garage queen - it will most definitely be put to work.
Re: Hardinge TFB
Finally got the wiring finished up this weekend.
Here's the schematic I created:
Hardinge Centroid HLV-H10140T.pdf
(460.13 KiB) Downloaded 248 times
And the finished control panel:
The panel is way more crowded that I would like, but the goal was to keep the conversion within the existing footprint of the lathe so it could go through my 32" wide basement door without disassembly. I have crossflow ventilation from the bottom left up to the top right and if I end up with a dead air spot on the bottom right below the servo drives, I can add a small muffin fan below the drives pulling cooler air from the left and pushing it up past the drives towards the vent.
And a small wiring box in the top of the right cabinet to collect all the wiring from the new conduit feedthroughs in the chip tray:
DICKEYBIRD
Re: Hardinge TFB
Post by DICKEYBIRD »
Oh wow, that is so beautiful! I love it when I see a project that has the time & energy invested in it doing things RIGHT! You gotta be very, very proud right now. :D
I recognize that Hoffman control box...24 x 24? If so I have the same model about half completed for the mill I'm building. Those Hoffmans are great. I have 2 of the larger size server fans on mine; one bottom right with a replaceable filter pulling in & blowing directly on the stepper drives, one upper left blowing out through a louvered vent plate. I bought a cheap DC fan speed controller that comes with a heat sensor which supposedly allows them to run slowly at first with a gradual increase to full 747 takeoff sounding speed if things get really hot. Haven't hooked it up yet though...too busy putzing around with the Acorn/lathe de-Mach'ing project. :)
Milton in Collierville, TN
