New schematic for Delta drives
dandonegan
CNC Control System Serial Number: A900460
Post by dandonegan »
I am installing an all-in-one control on a Hurco MD1 with a 12 position tool changer. I'm installing a new AC drive and am using a Delta C 2000. Seeing that the Delta VE is no longer available. I was hoping that you could supply us with an updated schematic as well as a new technical document outlining the recommended drive settings.
dan
Re: New schematic for Delta drives
dan, hello. i'll check and see if we have done the delta c 2000. in the meantime you can use the generic allin1dc to VFD schematic as a guide. using the Delta manual, its pretty easy to cross reference the connector label functions and make the proper connections to the allin1dc.
this link contains a zip file with several useful Allin1dc schematics in PDF format.. download it and unzip it to a folder and then take a look at the one named ALLIN1DC SPINDLE INVERTER.pdf
http://www.centroidcnc.com/downloads/al ... matics.zip
dandonegan
Thanks Keith,
Yes, that is the drawing that I'm using currently. I thought you would like to update your official schematic seeing that that other drive is no longer available.
What I was most interested in getting from you guys was a recommendations on the drive parameter setting.
Thanks for the quick response.
dan
dandonegan
Good morning,
Would it be possible to get a copy of your schematic drawings in AutoCAD format so that they can be edited? I can take just about any format.
dan
