MPU11 Ethernet LED
matt01
MPU11 Ethernet LED
Post by matt01 »
Hello,
I am having an issue with my Ethernet connection from my PC to the MPU11 board. I had everything running really well, but for some reason i am now having connectivity issues. At first i was just seeing my PC displaying "connected" for a few seconds then it displayed "disconnected" this would repeat several times a minute. Even when i would see that it was connected, only "sent packets" were being accumulated no packets were being received. With this condition the MPU Led's +5, DSP_OK , and FPGA-OK were all solid lit and DSP-Debug flashed every second, but no communication with the PC.
My last power up the four MPU11 LED's were diplayed as follows: +5, DSP-OK, and DSP_DSP-DeBug were all lit and FPGA flashed really fast.
maybe i need to re-boot the system?
Matt
diycncscott
Re: MPU11 Ethernet LED
Post by diycncscott »
Matt,
The DSP LED flashed very fast for 15-30 seconds while the MPU11 initializes. After that it settles as you describe.
Can you ping your mpu11 and nic
From a comand prompt:
ping 10.168.41.1
and
ping 10.168.41.2
matt01
Post by matt01 »
Hi Scott,
Thanks for the fast reply! I will ping the ports and see what happens. This AJAX hardware is pretty impressive, great bang for the buck!
Matt
