Virtual Control Panel VCP wont' start (resolved, use USA region Win10 settings)
Peppe
CNC Control System Serial Number: 38D2696FED7C-0426180875
Post by Peppe »
Hello
Updated from v4.12 to v4.14 and after that VirtualControlPanel does not work.
Has changed in Wizard on and off, sees an icon in the activation field for a few seconds and nothing more What can I do to make it work
Re: Updated to Acorn CNC12 v4.14
Please post a fresh report.
For us to be able to help you out.
viewtopic.php?f=60&t=1043
Peppe
Post by Peppe »
Fresh report
report_38D2696FED7C-0426180875_2019-03-18_20-49-47.zip
(238.69 KiB) Downloaded 372 times
try and set your display size to 1920x1080 (currently it is at 2560x1440)
and reboot.
Peppe
Post by Peppe »
No Virtualcontrolpanel with v4.14 1920x1080 and reboot
Peppe
Post by Peppe »
Located the error on CNC12 V4.14
If I have Swedish on windows 10 it doesn't work, If I change to English it works
see attached picture
Re: Updated to Acorn CNC12 v4.14 VirtualControlPanel (resolved)
Hello. yes, Windows 10 should be set on USA English and region should be USA so number formats (periods in stead of commas) are correct for CNC12, and you will need a USA keyboard.
Racedirector
Post by Racedirector »
cnckeith wrote: Thu Mar 21, 2019 7:38 pm ... region should be USA so number formats (periods in stead of commas) are correct for CNC12.....
Is this the case for other countries including Australia? We use the periods etc but date formats etc are different from the US.
Cheers
Re: Updated to Acorn CNC12 v4.14 VirtualControlPanel (resolved, Windows Region Issue))
we have not tested nor claim to support all the various windows 10 regions/country settings.
apparently some of them work and others don't. I haven't heard anyone from down under complaining so i assume you are going to be ok.
I do know some of the Euro keyboard and numbering system settings in Windows are guaranteed not to work.
if your language and region settings are working, then "no worries" if not, set Windows back to USA defaults..like this.
Set Win10 to USA English and numbering system to be sure and dedicate the CNCPC to the CNC machine tool.
go to region and language window. and click advanced.
set to USA english
go to administrative , select Formats
and click "additional settings"
and click "reset" , apply , ok...etc...
