Tool Setting Options For Routers and Mills
Centroid_Tech
Re: Tool Setting Options For Routers and Mills
Post by Centroid_Tech »
I'm assuming that you are referring to the custom tool change macro, mfunc6.mac, correct? It actually looks like the custom tool change macro was moving at a fixed feedrate of 100mm/min when the system is in metric mode or 100in/min when the system is in imperial mode. Please copy the attached file into the c:\cncm directory and see if that works for you. That will jog based on the value of parameter 14.
mfunc6.mac
(9.05 KiB) Downloaded 208 times
Mq1506
Post by Mq1506 »
Hmm, something weird is going on. I loaded the macro you supplied. Same issue. As a test I divided param 14 by 10 so it became 15. Then it did the fast probe at 152 mm/min. Acceptable, I was able to run the macro fully and touch off but the Z axis setting wasn't anywhere close (at least 200mm off) I divided #71 by 10, closer but still way off. I then tried converting #71 to inches which got it really close but it was still roughly 5mm off. I think something is up with how the macro handles mm vs inches.
slodat
Post by slodat »
Installed a stationary tool height probe and switched to Clint's m6 macro. Works great. This saves a ton of time on tool changes within a job.
Thank you!
cbb1962
CNC Control System Serial Number: 38D2695C8301-0122180576
Post by cbb1962 »
After using the Original Macro for a while I found there were times when I only needed the movable plate. I modified the Macro to include this functionality.
mfunc6.mac
(12.7 KiB) Downloaded 272 times
Clint in NW Arkansas
cbb1962
Post by cbb1962 »
One weird thing that I have noticed: Whenever I power cycle the Acorn the M6 macro doesn't work properly (the Z-axis moves up instead of moving down looking for the touch plate) until I either activate the TT1 or touch the moveable touch plate to the bit.
Is this normal or is there something wonky with my setup??
Thanks!
Gary Campbell
Post by Gary Campbell »
Clint...
Was the machine homed after the reboot?
CNC Depot Modular ATC kits
cbb1962
Post by cbb1962 »
Yes
MecTechMike
Post by MecTechMike »
Folks,
I've come across a curious issue. I am currently using the original tool touch off code "mfunc6JogToToolTouchOff-tt1.mac". It works great, and many thanks to the author. But this macro interprets parameter 71 differently than CNC12. For the macro, you enter the thickness of the probe as a positive number, and the macro subtracts this off the measurement to get to the part/reference. For CNC12, you have to enter the negative value for parameter 71 if you go through the part setup menu.
Is there some pilot error on my part here, or is there a misinterpretation of the two zeroing methods?
Mike
Gary Campbell
Mike...
As I remember it, and I am not reviewing the code now, the action is to set the Current Z position as the value of parm 71. In my reasoning, the number would have to be positive as the touchoff device would be above the surface that you wish to reference the Z to.
Are you sure something else is not amiss?
cncnewguy
CNC Control System Serial Number: 38D2695947FE-1222170399
Post by cncnewguy »
I just performed the below option:
2. Manually jog the tool over the Tool Touch Off Device and press Cycle start to probe the the Tool Touch Off Device: Download here:
(9.11 KiB) Downloaded 175 times
Save as : c:\cncm\mfunc6.mac
When I go into setup I do not get pop up dialog boxes that give me options lie in the videos. I just get the same original "set part position" screen and when I select "auto" the z axis drives Negitive towards the touch plate. Once it contacts the plate it backs off slowly and then moves back down to touch it again and only then does the relay click and the Z axis is set to the dimention I inputed. In my case it is .98.
Three questions: How come I am not seeing the Marco display? Why when I select "save" does it reset to 0.000? And Why does it not reflect a positive value since it is infact 1 inch above the work surface?
Thank you
